Hii Team ,
I am trying to do secure boot with hab and i have done all the steps from
Encrypted boot loader on SabreSD i.MX6q board
but I stucked at :=
gcc -o cst -I ../hdr -L ../../../linux64/lib *.c -lfrontend -lcrypto
gcc -o cst_encrypt -I ../hdr -L ../../../linux64/lib *.c -lfrontend -lcrypto
/tmp/ccWNF7ae.o: In function `sk_X509_new_null':
adapt_layer_openssl.c:(.text+0x5): undefined reference to `OPENSSL_sk_new_null'
/tmp/ccWNF7ae.o: In function `sk_X509_push':
adapt_layer_openssl.c:(.text+0x2a): undefined reference to `OPENSSL_sk_push'
/tmp/ccWNF7ae.o: In function `sk_X509_pop_free':
adapt_layer_openssl.c:(.text+0x4f): undefined reference to `OPENSSL_sk_pop_free'
/tmp/ccWNF7ae.o: In function `gen_sig_data_ecdsa':
adapt_layer_openssl.c:(.text+0xa4f): undefined reference to `EVP_PKEY_get0_EC_KEY'
adapt_layer_openssl.c:(.text+0xa8d): undefined reference to `EVP_PKEY_get0_EC_KEY'
adapt_layer_openssl.c:(.text+0xbda): undefined reference to `ECDSA_SIG_get0'
/tmp/ccy3RGpA.o: In function `generate_hash':
openssl_helper.c:(.text+0x1f): undefined reference to `EVP_MD_CTX_new'
/tmp/ccy3RGpA.o: In function `sign_data':
openssl_helper.c:(.text+0x4b3): undefined reference to `EVP_MD_CTX_new'
openssl_helper.c:(.text+0x520): undefined reference to `EVP_MD_CTX_free'
openssl_helper.c:(.text+0x5a6): undefined reference to `EVP_MD_CTX_free'
openssl_helper.c:(.text+0x5c5): undefined reference to `EVP_MD_CTX_free'
/tmp/ccy3RGpA.o: In function `ver_sig_data':
openssl_helper.c:(.text+0xc8b): undefined reference to `EVP_PKEY_get0_RSA'
openssl_helper.c:(.text+0xd49): undefined reference to `ECDSA_SIG_set0'
openssl_helper.c:(.text+0xd78): undefined reference to `EVP_PKEY_get0_EC_KEY'
../../../linux64/lib/libfrontend.a(srk_helper.o): In function `srk_entry_pkcs1':
srk_helper.c:(.text+0x90): undefined reference to `EVP_PKEY_get0_RSA'
srk_helper.c:(.text+0xa8): undefined reference to `RSA_get0_key'
../../../linux64/lib/libfrontend.a(srk_helper.o): In function `srk_entry_ec':
srk_helper.c:(.text+0x564): undefined reference to `EVP_PKEY_get0_EC_KEY'
srk_helper.c:(.text+0x5d3): undefined reference to `EVP_PKEY_get0_EC_KEY'
/usr/bin/ld: ../../../linux64/lib/libfrontend.a(err.o): unrecognized relocation (0x2a) in section `.text'
/usr/bin/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status
ubuntuforedd@Sachinedd2:~/Downloads/cstool/code/back_end/src$ l
adapt_layer_openssl.c openssl_helper.c pkey.c ssl_wrapper.c
Regards ,
Pramod Kumar
Solved! Go to Solution.
Please refer to app note "Encrypted Boot on HABv4 and CAAM Enabled Devices".
https://www.nxp.com/docs/en/application-note/AN12056.pdf
In particular, look at section 4.2. (Requirements).
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
Hello ,
But this issue is not of ubuntu this one is of cst tool .
Pramod
I expect, that we have here some general, environment, packages installations
problem. At least, I cannot reproduce the issue.
Yuri.
hii Yuri ,
In-between compilation I am facing below issue :
$ gcc -o cst -I ../hdr -L ../../../linux32/lib *.c -lfrontend -lcrypto -m32
/usr/bin/ld: skipping incompatible //usr/local/lib/libcrypto.so when searching for -lcrypto
/usr/bin/ld: skipping incompatible //usr/local/lib/libcrypto.a when searching for -lcrypto
/usr/bin/ld: cannot find -lcrypto
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.8/libgcc.a when searching for -lgcc
/usr/bin/ld: cannot find -lgcc
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.8/libgcc_s.so when searching for -lgcc_s
/usr/bin/ld: cannot find -lgcc_s
Is Your Linux host 64- or 32-bit?
Hii ,
Can you please share the exact steps for the same , from scratch on-wards .
just tried on my 64-bit host (Debian 9), as stated in "Release_Notes.txt" of the CST 3.1.0 package:
To relink on 64 bit Linux machines:
This requires the GCC compiler and the OpenSSL header files and
library. For example on Ubuntu machines:
sudo apt-get install gcc libssl-dev
cd <CST install directory/code/back_end/src
It works!
Yuri.
Hii Yuri ,
After execute the same command I got the error .
/tmp/ccKuEo7P.o: In function `sk_X509_new_null':
/tmp/ccKuEo7P.o: In function `sk_X509_push':
/tmp/ccKuEo7P.o: In function `sk_X509_pop_free':
/tmp/ccKuEo7P.o: In function `gen_sig_data_ecdsa':
/tmp/ccSxXwCG.o: In function `generate_hash':
/tmp/ccSxXwCG.o: In function `sign_data':
/tmp/ccSxXwCG.o: In function `ver_sig_data':
Regards ,
Pramod
looks like the only way - try new (clean) Ununtu host installation.
Yuri.
My host is of 64 bit . and imx (client) machine is of 32 bit .
The CST is working only on host PC, therefore use 64-bit configuration.
I am using 64 bit configuration then I am getting error
$ gcc -o cst -I ../hdr -L ../../../linux64/lib *.c -lfrontend -lcrypto
Is the OpenSSL library installed?
sudo apt-get install libssl-dev
Yes already installed .
$ apt-get install libssl-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
libssl-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 106 not upgraded.
version libssl1.1
Hii Yuri ,
Have you did some R&D and share the steps to do the same from scratch on-wards .
Yuri
button. Thank you!
Hi Yuri ,
We need to generate our own key and after done the below steps I am facing some issue . please check it and do needful for me . Please check the full process .
./hab4_pki_tree.sh
This script is a part of the Code signing tools for Freescale's
High Assurance Boot. It generates a basic PKI tree. The PKI
tree consists of one or more Super Root Keys (SRK), with each
SRK having two subordinate keys:
+ a Command Sequence File (CSF) key
+ Image key.
Additional keys can be added to the PKI tree but a separate
script is available for this. This this script assumes openssl
is installed on your system and is included in your search
path. Finally, the private keys generated are password
protectedwith the password provided by the file key_pass.txt.
The format of the file is the password repeated twice:
my_password
my_password
All private keys in the PKI tree are in PKCS #8 format will be
protected by the same password.
Do you want to use an existing CA key (y/n)?: y
Enter CA key name: STJ12345
Enter CA certificate name: STJSECUREBOOT
Do you want to use Elliptic Curve Cryptography (y/n)?: n
Enter key length in bits for PKI tree: 2048
Enter PKI tree duration (years): 10
How many Super Root Keys should be generated? 4
Do you want the SRK certificates to have the CA flag set? (y/n)?: y
A default 'serial' file was created!
A default file 'key_pass.txt' was created with password = test!
+ Generating SRK key and certificate 1 +
Generating RSA private key, 2048 bit long modulus (2 primes)
e is 65537 (0x010001)
Using configuration from ../ca/openssl.cnf
Can't open STJ12345.pem for reading, No such file or directory
139889208842048:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('STJ12345.pem','r')
139889208842048:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
unable to load CA private key
Can't open ../crts/SRK1_sha256_2048_65537_v3_ca_crt.pem for reading, No such file or directory
140669524993856:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/SRK1_sha256_2048_65537_v3_ca_crt.pem','r')
140669524993856:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
unable to load certificate
+ Generating CSF key and certificate 1 +
140443417438016:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/SRK1_sha256_2048_65537_v3_ca_crt.pem','r')
140443417438016:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
Can't open ../crts/CSF1_1_sha256_2048_65537_v3_usr_crt.pem for reading, No such file or directory
140359138977600:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/CSF1_1_sha256_2048_65537_v3_usr_crt.pem','r')
140359138977600:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
+ Generating IMG key and certificate 1 +
140660236867392:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/SRK1_sha256_2048_65537_v3_ca_crt.pem','r')
140660236867392:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
Can't open ../crts/IMG1_1_sha256_2048_65537_v3_usr_crt.pem for reading, No such file or directory
139938271336256:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/IMG1_1_sha256_2048_65537_v3_usr_crt.pem','r')
139938271336256:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
+ Generating SRK key and certificate 2 +
140461707548480:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('STJ12345.pem','r')
140461707548480:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
Can't open ../crts/SRK2_sha256_2048_65537_v3_ca_crt.pem for reading, No such file or directory
140388714141504:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/SRK2_sha256_2048_65537_v3_ca_crt.pem','r')
140388714141504:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
+ Generating CSF key and certificate 2 +
139995852949312:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/SRK2_sha256_2048_65537_v3_ca_crt.pem','r')
139995852949312:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
Can't open ../crts/CSF2_1_sha256_2048_65537_v3_usr_crt.pem for reading, No such file or directory
140257066841920:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/CSF2_1_sha256_2048_65537_v3_usr_crt.pem','r')
140257066841920:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
+ Generating IMG key and certificate 2 +
140189396019008:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/SRK2_sha256_2048_65537_v3_ca_crt.pem','r')
140189396019008:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
Can't open ../crts/IMG2_1_sha256_2048_65537_v3_usr_crt.pem for reading, No such file or directory
140477171283776:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/IMG2_1_sha256_2048_65537_v3_usr_crt.pem','r')
140477171283776:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
+ Generating SRK key and certificate 3 +
140199426692928:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('STJ12345.pem','r')
140199426692928:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
Can't open ../crts/SRK3_sha256_2048_65537_v3_ca_crt.pem for reading, No such file or directory
140036135479104:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/SRK3_sha256_2048_65537_v3_ca_crt.pem','r')
140036135479104:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
+ Generating CSF key and certificate 3 +
140226137646912:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/SRK3_sha256_2048_65537_v3_ca_crt.pem','r')
140226137646912:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
Can't open ../crts/CSF3_1_sha256_2048_65537_v3_usr_crt.pem for reading, No such file or directory
140629534500672:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/CSF3_1_sha256_2048_65537_v3_usr_crt.pem','r')
140629534500672:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
+ Generating IMG key and certificate 3 +
140115059648320:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/SRK3_sha256_2048_65537_v3_ca_crt.pem','r')
140115059648320:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
Can't open ../crts/IMG3_1_sha256_2048_65537_v3_usr_crt.pem for reading, No such file or directory
140170731870016:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/IMG3_1_sha256_2048_65537_v3_usr_crt.pem','r')
140170731870016:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
+ Generating SRK key and certificate 4 +
139783788898112:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('STJ12345.pem','r')
139783788898112:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
Can't open ../crts/SRK4_sha256_2048_65537_v3_ca_crt.pem for reading, No such file or directory
140251085322048:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/SRK4_sha256_2048_65537_v3_ca_crt.pem','r')
140251085322048:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
+ Generating CSF key and certificate 4 +
140422708868928:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/SRK4_sha256_2048_65537_v3_ca_crt.pem','r')
140422708868928:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
Can't open ../crts/CSF4_1_sha256_2048_65537_v3_usr_crt.pem for reading, No such file or directory
139739998271296:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/CSF4_1_sha256_2048_65537_v3_usr_crt.pem','r')
139739998271296:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
+ Generating IMG key and certificate 4 +
139869409961792:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/SRK4_sha256_2048_65537_v3_ca_crt.pem','r')
139869409961792:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
Can't open ../crts/IMG4_1_sha256_2048_65537_v3_usr_crt.pem for reading, No such file or directory
139792348456768:error:02001002:system library:fopen:No such file or directory:crypto/bio/bss_file.c:72:fopen('../crts/IMG4_1_sha256_2048_65537_v3_usr_crt.pem','r')
139792348456768:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c:79:
Regards ,
Pramod
HIII ,
Can you please provide me the steps from scratch on wards for secure boot .
Hii Yuri ,
Dear Team ,
One more thing I need to be understand as I am a fresher in Linux environment , My system is of 64 bit but the IMX 6ul machine is of 32 bit . So , give some steps and suggestion to do for the same .
