T2080 XFI 10GBase-T port support
Question asked by Filemón Pi on Mar 6, 2019
Latest reply on Mar 14, 2019 by Filemón Pi
Hi everybody,
I am designing a node based on T2080 and I want to implement one 10Gb Ethernet port.
I read on T2080RDBPCUG.pdf document the following sentence: "The T2080 only supports evaluation of the XFI protocol using Aquantia AQ1202 dual port 10GBase-T PHY".
That means the T2080 only works using the Aquantia AQ1202 IC or it refers to XFI protocol where, for example, I can use other PHY IC manufacturer as such Marvell or Broadcom?
Thanks on advance.
Regards.
