FRDM-KL27Z board could not shown on the Board / Device selection page
albert_zhou
I reset up MCUXpresso on a new computer. The project cannot be compiled. The window pop up says I need to install SDK, However, when I plug in the SDK board, (LCD blinking is fine), My FRDM-KL27Z cannot shown on the Board and/or Device selection page. That is different from the old computer. I don't know how to fix it. Without the setup, it seems MCUXpresso does not allow me to edit MCU setting.
Albert
albert_zhou
Hi Aldo,
Thanks for your reply. I download the SDK_2.5.0_FRDM-KL27Z.zip. But I have trouble to install the SDK. how to work with the dragging into installed SDK view? where is the "installed SDK view"? I clicked new project, It pops out window "Board and/or device select page". I tried dragging the zip file into any where in the window  but does not work.
Please advise? I used import achieved files that seems opened file but did not solve the problem.
Albert
AldoG
You should be able to see a tab like this where you can drag and drop your downloaded SDK
If you happend to close it, you can re-open this tap just go to window > show view > other
then select MCUXpresso IDE > installed SDKs, click open and you should be good to go
Hope this helps,
Aldo
albert_zhou
Hi Aldo,
I followed your instruction. It works great with my two project QN9080 and KL27Z64xxx4.
Thanks a lot!
Albert
AldoG
Hello Albert,
You'll need to download and install the SDK for your board (FRDM-KL27Z) on your new computer,
Please follow this  user guide [https://www.nxp.com/docs/en/user-guide/MCUXpresso_IDE_User_Guide.pdf]
Chapter 5.2 SDK Part Support, there you'll find a step by step guide to download and install the SDK
you can download the SDK here: [https://mcuxpresso.nxp.com/en/select]
Aldo.
