LPC81x UID Register Address
jose_oga
Hello Everyone,
Is there any way in which I can read unique 128-bit ID from the LPC81x directly from a memory register?
My application is using SWD connection for writing/reading the registers and using IAP would make the process much more complex.
I haven't been able to find the address of the UID on the User Manual, examples, or anywhere else.
Thanks!
gerhardk
Read four words from 0x0C000080
jeremyzhou
Hi Jose Ogando,
To my knowledge, the UID register address is not public, so IAP command is the best method to read the UID register.
TIC
jose_oga
Thanks for the quick response!
You mention that IAP command is the best method. Are there any other options?
Thanks!
gerhardk
theophileleroy
Where can I find this address for LPC802 ?
jose_oga
This seems to be working.
Thanks a lot!
jeremyzhou
Hi Jose Ogando,
1) Are there any other options?
-- I'm afraid it doesn't have other option
TIC
