Two Nand Memory on Imx6 with qnx6.6.0
ssankar8
                  I am using imx6d custom board with Qnx 6.6.0 .I am using two nand memory in my custom board.
Is the etfs driver is capable of handling the two nand memory, with cs0 and cs1 chip select. Let me know what are the changes to be done for using two nand memory.
ssankar8
From IMX through the gpmi can i mount two nand chip and access them simultaneously..
Yuri
   I think it would be better to apply directly to QNX support regarding nand using under their OS.
Yuri.
