Error when I bitbake meta-toolchain-qt5 (error qtbase)
maximenoah
Can you help me please ?
When i try to bitbake meta-toolchain-qt5, i have many errors with qtbase and others (errors are in red) :
noahm1@noahm1-Latitude-E6520:~/var-fslc-yocto$ MACHINE=var-som-mx6 DISTRO=fslc-x11 . setup-environment  build_x11
Welcome to Freescale Community BSP
The Yocto Project has extensive documentation about OE including a
reference manual which can be found at:
    http://yoctoproject.org/documentation
For more information about OpenEmbedded see their website:
    http://www.openembedded.org/
You can now run 'bitbake <target>'
Common targets are:
    core-image-minimal
    meta-toolchain
    meta-toolchain-sdk
    adt-installer
    meta-ide-support
Your configuration files at build_x11 have not been touched.
noahm1@noahm1-Latitude-E6520:~/var-fslc-yocto/build_x11$ bitbake meta-toolchain-qt5
Loading cache: 100% |############################################| Time: 0:00:00
Loaded 3373 entries from dependency cache.
Parsing recipes: 100% |##########################################| Time: 0:00:02
Parsing of 2471 .bb files complete (2470 cached, 1 parsed). 3374 targets, 206 skipped, 3 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.38.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "arm-fslc-linux-gnueabi"
MACHINE = "var-som-mx6"
DISTRO = "fslc-x11"
DISTRO_VERSION = "2.5"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta
meta-poky = "HEAD:5887f81bb585d0a697b91daf7f7dd6ccb1d444e2"
meta-oe
meta-multimedia = "HEAD:b0950aeff5b630256bb5e25ca15f4d59c115e7c1"
meta-freescale = "HEAD:50fbef4593f79949ab6c67b2582d8b5c8b24838a"
meta-freescale-3rdparty = "HEAD:42c913b8fd266f72950a9ce305d316c0ecb64343"
meta-freescale-distro = "HEAD:f7e2216e93aff14ac32728a13637a48df436b7f4"
meta-browser = "HEAD:d807b901b0b68b478093964bd60a77b9376b3f12"
meta-gnome
meta-networking
meta-python = "HEAD:b0950aeff5b630256bb5e25ca15f4d59c115e7c1"
meta-qt5 = "HEAD:4b96f70a083eacfc4ff4a45d4efbb2d131f88c82"
meta-swupdate = "HEAD:dae0d3e906e764e02a8b6357e7698bfde278fa6e"
meta-variscite-fslc = "HEAD:6197d151647fbdbdd7afb995448afb43883fa83e"
Initialising tasks: 100% |#######################################| Time: 0:00:04
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: nativesdk-qtbase-5.10.1+gitAUTOINC+6c6ace9d23-r0 do_compile: oe_runmake failed
ERROR: nativesdk-qtbase-5.10.1+gitAUTOINC+6c6ace9d23-r0 do_compile: Function failed: do_compile (log file is located at /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/temp/log.do_compile.9236)
ERROR: Logfile of failure stored in: /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/temp/log.do_compile.9236
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 4 MAKEFLAGS=-j 4 OE_QMAKE_COMPILER=x86_64-fslcsdk-linux-gcc --sysroot=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot OE_QMAKE_CC=x86_64-fslcsdk-linux-gcc --sysroot=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot OE_QMAKE_CXX=x86_64-fslcsdk-linux-g++ --sysroot=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot OE_QMAKE_CFLAGS= -O2 -pipe OE_QMAKE_CXXFLAGS= -O2 -pipe OE_QMAKE_LINK=x86_64-fslcsdk-linux-g++ --sysroot=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot OE_QMAKE_LDFLAGS=-Wl,-O1 OE_QMAKE_AR=x86_64-fslcsdk-linux-ar OE_QMAKE_STRIP=echo OE_QMAKE_INCDIR_QT=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot//opt/fslc-x11/2.5/sysroots/x86_64-fslcsdk-linux/usr/include/qt5
| cd src/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/src.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qmake/ && ( test -e Makefile.qmake-aux || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile.qmake-aux /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/qmake/qmake-aux.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile.qmake-aux
| cd doc/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/doc/doc.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[1]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/doc'
| make[1]: Nothing to be done for 'first'.
| make[1]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/doc'
| make[1]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src'
| cd 3rdparty/pcre2/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/3rdparty/pcre2/pcre2.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd tools/bootstrap/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/bootstrap/bootstrap.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd corelib/ && ( test -e Makefile.qtzlib || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile.qtzlib /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/corelib/qtzlib.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile.qtzlib
| make[1]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/qmake'
| make binary
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/qmake'
| make[2]: Nothing to be done for 'binary'.
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/qmake'
| make[1]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/qmake'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/corelib'
| make[2]: Nothing to be done for 'first'.
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/corelib'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/3rdparty/pcre2'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/3rdparty/pcre2'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/bootstrap'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/bootstrap'
| cd tools/moc/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/moc/moc.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd tools/rcc/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/rcc/rcc.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd tools/qlalr/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/qlalr/qlalr.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd tools/qfloat16-tables/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/qfloat16-tables/qfloat16-tables.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qfloat16-tables'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qfloat16-tables'
| cd tools/bootstrap-dbus/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/bootstrap-dbus/bootstrap-dbus.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/rcc'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/rcc'
| cd tools/uic/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/uic/uic.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qlalr'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/moc'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/moc'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qlalr'
| cd tools/qvkgen/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/qvkgen/qvkgen.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd corelib/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/corelib/corelib.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/bootstrap-dbus'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/bootstrap-dbus'
| cd tools/qdbusxml2cpp/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/qdbusxml2cpp/qdbusxml2cpp.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/uic'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/uic'
| cd tools/qdbuscpp2xml/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/qdbuscpp2xml/qdbuscpp2xml.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qvkgen'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qvkgen'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qdbusxml2cpp'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qdbusxml2cpp'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qdbuscpp2xml'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qdbuscpp2xml'
| rm -f libQt5Core.so.5.10.1 libQt5Core.so libQt5Core.so.5 libQt5Core.so.5.10
| linking ../../lib/libQt5Core.so.5.10.1
| .obj/qcryptographichash.o: file not recognized: File truncated
| collect2: error: ld returned 1 exit status
| Makefile:1152: recipe for target '../../lib/libQt5Core.so.5.10.1' failed
| make[2]: *** [../../lib/libQt5Core.so.5.10.1] Error 1
| Makefile:216: recipe for target 'sub-corelib-make_first' failed
| make[1]: *** [sub-corelib-make_first] Error 2
| make[1]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src'
| Makefile:48: recipe for target 'sub-src-make_first' failed
| make: *** [sub-src-make_first] Error 2
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /home/noahm1/var-fslc-yocto/build_x11/tmp/work/x86_64-nativesdk-fslcsdk-linux/nativesdk-qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/temp/log.do_compile.9236)
ERROR: Task (/home/noahm1/var-fslc-yocto/sources/meta-qt5/recipes-qt/qt5/nativesdk-qtbase_git.bb:do_compile) failed with exit code '1'
ERROR: qtbase-5.10.1+gitAUTOINC+6c6ace9d23-r0 do_compile: oe_runmake failed
ERROR: qtbase-5.10.1+gitAUTOINC+6c6ace9d23-r0 do_compile: Function failed: do_compile (log file is located at /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/temp/log.do_compile.9151)
ERROR: Logfile of failure stored in: /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/temp/log.do_compile.9151
Log data follows:
| NOTE: make -j 4 MAKEFLAGS=-j 4 OE_QMAKE_COMPILER=arm-fslc-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot OE_QMAKE_CC=arm-fslc-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot OE_QMAKE_CXX=arm-fslc-linux-gnueabi-g++ -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot OE_QMAKE_CFLAGS= -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0=/usr/src/debug/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0 -fdebug-prefix-map=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot= -fdebug-prefix-map=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native= OE_QMAKE_CXXFLAGS= -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0=/usr/src/debug/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0 -fdebug-prefix-map=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot= -fdebug-prefix-map=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native= -fvisibility-inlines-hidden OE_QMAKE_LINK=arm-fslc-linux-gnueabi-g++ -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot OE_QMAKE_LDFLAGS=-Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed OE_QMAKE_AR=arm-fslc-linux-gnueabi-ar OE_QMAKE_STRIP=echo OE_QMAKE_INCDIR_QT=/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot//usr/include/qt5
| cd src/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/src.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qmake/ && ( test -e Makefile.qmake-aux || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile.qmake-aux /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/qmake/qmake-aux.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile.qmake-aux
| cd doc/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/doc/doc.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[1]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/doc'
| make[1]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/doc'
| make[1]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/qmake'
| make binary
| make[1]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src'
| cd corelib/ && ( test -e Makefile.qtzlib || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile.qtzlib /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/corelib/qtzlib.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile.qtzlib
| cd tools/bootstrap/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/bootstrap/bootstrap.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd 3rdparty/pcre2/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/3rdparty/pcre2/pcre2.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/qmake'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/qmake'
| make[1]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/qmake'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/corelib'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/corelib'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/3rdparty/pcre2'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/3rdparty/pcre2'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/bootstrap'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/bootstrap'
| cd tools/moc/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/moc/moc.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd tools/rcc/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/rcc/rcc.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd tools/qlalr/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/qlalr/qlalr.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd tools/qfloat16-tables/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/qfloat16-tables/qfloat16-tables.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/rcc'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/rcc'
| cd tools/qvkgen/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/qvkgen/qvkgen.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/moc'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/moc'
| cd tools/uic/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/uic/uic.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qfloat16-tables'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qfloat16-tables'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qlalr'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qlalr'
| cd tools/bootstrap-dbus/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/bootstrap-dbus/bootstrap-dbus.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd corelib/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/corelib/corelib.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qvkgen'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qvkgen'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/uic'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/uic'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/bootstrap-dbus'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/bootstrap-dbus'
| cd tools/qdbusxml2cpp/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/qdbusxml2cpp/qdbusxml2cpp.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd tools/qdbuscpp2xml/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/tools/qdbuscpp2xml/qdbuscpp2xml.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qdbusxml2cpp'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qdbusxml2cpp'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qdbuscpp2xml'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/tools/qdbuscpp2xml'
| cd network/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/network/network.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd xml/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/xml/xml.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd sql/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/sql/sql.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd gui/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/gui/gui.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/sql'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/sql'
| cd dbus/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/dbus/dbus.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/xml'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/xml'
| cd concurrent/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/concurrent/concurrent.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/network'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/network'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/dbus'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/dbus'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/concurrent'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/concurrent'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/gui'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/gui'
| cd openglextensions/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/openglextensions/openglextensions.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd platformheaders/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformheaders/platformheaders.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/openglextensions'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/openglextensions'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformheaders'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformheaders'
| cd platformsupport/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformsupport/platformsupport.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd widgets/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/widgets/widgets.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport'
| cd devicediscovery/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformsupport/devicediscovery/devicediscovery.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd eventdispatchers/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformsupport/eventdispatchers/eventdispatchers.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd edid/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformsupport/edid/edid.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/edid'
| make[3]: Nothing to be done for 'first'.
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/edid'
| cd fbconvenience/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformsupport/fbconvenience/fbconvenience.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/devicediscovery'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/devicediscovery'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/eventdispatchers'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/eventdispatchers'
| cd fontdatabases/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformsupport/fontdatabases/fontdatabases.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd themes/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformsupport/themes/themes.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/fbconvenience'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/fbconvenience'
| cd input/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformsupport/input/input.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/fontdatabases'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/fontdatabases'
| cd services/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformsupport/services/services.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/themes'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/themes'
| cd platformcompositor/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformsupport/platformcompositor/platformcompositor.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/services'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/services'
| cd eglconvenience/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformsupport/eglconvenience/eglconvenience.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/input'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/input'
| cd accessibility/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/platformsupport/accessibility/accessibility.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/platformcompositor'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/platformcompositor'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/eglconvenience'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/eglconvenience'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/accessibility'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport/accessibility'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/platformsupport'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/widgets'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/widgets'
| cd testlib/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/testlib/testlib.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd opengl/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/opengl/opengl.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd printsupport/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/printsupport/printsupport.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/testlib'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/testlib'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/opengl'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/opengl'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/printsupport'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/printsupport'
| cd plugins/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/plugins.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins'
| cd sqldrivers/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/sqldrivers/sqldrivers.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd bearer/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/bearer/bearer.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd platforms/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforms/platforms.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd platforminputcontexts/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforminputcontexts/platforminputcontexts.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/bearer'
| cd generic/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/bearer/generic/generic.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforminputcontexts'
| cd ibus/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforminputcontexts/ibus/ibus.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms'
| cd minimal/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforms/minimal/minimal.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/sqldrivers'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/sqldrivers'
| cd offscreen/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforms/offscreen/offscreen.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/bearer/generic'
| make[4]: Nothing to be done for 'first'.
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/bearer/generic'
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforminputcontexts/ibus'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforminputcontexts/ibus'
| cd connman/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/bearer/connman/connman.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd compose/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforminputcontexts/compose/compose.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/minimal'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/minimal'
| cd xcb/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforms/xcb/xcb.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/offscreen'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/offscreen'
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/bearer/connman'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/bearer/connman'
| cd linuxfb/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforms/linuxfb/linuxfb.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd networkmanager/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/bearer/networkmanager/networkmanager.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforminputcontexts/compose'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforminputcontexts/compose'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforminputcontexts'
| cd platformthemes/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platformthemes/platformthemes.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/xcb'
| ( test -e Makefile.xcb_qpa_lib || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile.xcb_qpa_lib /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforms/xcb/xcb_qpa_lib.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile.xcb_qpa_lib
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platformthemes'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platformthemes'
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/linuxfb'
| cd imageformats/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/imageformats/imageformats.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/linuxfb'
| cd vnc/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforms/vnc/vnc.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/bearer/networkmanager'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/bearer/networkmanager'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/bearer'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/imageformats'
| cd generic/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/generic/generic.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd jpeg/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/imageformats/jpeg/jpeg.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic'
| cd evdevmouse/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/generic/evdevmouse/evdevmouse.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/xcb'
| make[5]: Nothing to be done for 'first'.
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/xcb'
| ( test -e Makefile.xcb-plugin || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile.xcb-plugin /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforms/xcb/xcb-plugin.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile.xcb-plugin
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/vnc'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/vnc'
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/imageformats/jpeg'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/imageformats/jpeg'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/imageformats'
| cd styles/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/styles/styles.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd printsupport/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/printsupport/printsupport.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic/evdevmouse'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic/evdevmouse'
| cd evdevtouch/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/generic/evdevtouch/evdevtouch.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd gl_integrations/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforms/xcb/gl_integrations/gl_integrations.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/styles'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/styles'
| cd evdevkeyboard/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/generic/evdevkeyboard/evdevkeyboard.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/printsupport'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/printsupport'
| cd evdevtablet/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/generic/evdevtablet/evdevtablet.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic/evdevtouch'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic/evdevtouch'
| cd tslib/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/generic/tslib/tslib.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/xcb/gl_integrations'
| cd xcb_egl/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/platforms/xcb/gl_integrations/xcb_egl/xcb_egl.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic/evdevtablet'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic/evdevtablet'
| cd tuiotouch/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/src/plugins/generic/tuiotouch/tuiotouch.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic/evdevkeyboard'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic/evdevkeyboard'
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic/tuiotouch'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic/tuiotouch'
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic/tslib'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic/tslib'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/generic'
| make[6]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/xcb/gl_integrations/xcb_egl'
| make[6]: Nothing to be done for 'first'.
| make[6]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/xcb/gl_integrations/xcb_egl'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/xcb/gl_integrations'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms/xcb'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins/platforms'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src/plugins'
| make[1]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/src'
| cd examples/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/examples.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd tests/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/tests.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[1]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples'
| cd corelib/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/corelib.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd embedded/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/embedded/embedded.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qpa/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/qpa/qpa.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd touch/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/touch/touch.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[1]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests'
| cd auto/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/auto.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd benchmarks/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/benchmarks.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qpa'
| cd windows/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/qpa/windows/windows.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto'
| cd dbus/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/dbus.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd gui/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/gui.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd corelib/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/corelib.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/embedded'
| Some of the required modules (if(embedded|x11):qtHaveModule(gui)) are not available.
| Skipped.
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/embedded'
| cd dbus/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/dbus/dbus.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks'
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/touch'
| cd corelib/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/corelib.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd pinchzoom/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/touch/pinchzoom/pinchzoom.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib'
| cd ipc/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/ipc/ipc.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qpa/windows'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qpa/windows'
| cd qrasterwindow/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/qpa/qrasterwindow/qrasterwindow.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui'
| cd io/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/io/io.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd kernel/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/kernel.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus'
| cd listnames/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/dbus/listnames/listnames.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus'
| cd qdbusconnection_delayed/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusconnection_delayed/qdbusconnection_delayed.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib'
| cd kernel/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/kernel/kernel.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/ipc'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/touch/pinchzoom'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/touch/pinchzoom'
| cd sharedmemory/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/ipc/sharedmemory/sharedmemory.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd fingerpaint/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/touch/fingerpaint/fingerpaint.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusconnection_delayed'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusconnection_delayed'
| cd qdbusabstractadaptor/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusabstractadaptor/qdbusabstractadaptor.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/listnames'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/listnames'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qpa/qrasterwindow'
| make[3]: Nothing to be done for 'first'.
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qpa/qrasterwindow'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qpa'
| cd network/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/network/network.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd pingpong/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/dbus/pingpong/pingpong.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel'
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io'
| cd qdir/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/io/qdir/qdir.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qbackingstore/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qbackingstore/qbackingstore.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel'
| cd qcoreapplication/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/kernel/qcoreapplication/qcoreapplication.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qdir'
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qcoreapplication'
| Some of the required modules (qtConfig(private_tests)) are not available.
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusabstractadaptor'
| Skipped.
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qcoreapplication'
| cd qmyserver/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusabstractadaptor/qmyserver/qmyserver.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd 10000/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/io/qdir/10000/10000.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/ipc/sharedmemory'
| cd qdeadlinetimer/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/kernel/qdeadlinetimer/qdeadlinetimer.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/ipc/sharedmemory'
| cd localfortuneserver/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/ipc/localfortuneserver/localfortuneserver.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/touch/fingerpaint'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/touch/fingerpaint'
| cd knobs/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/touch/knobs/knobs.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/pingpong'
| ( test -e Makefile.ping || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile.ping /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/dbus/pingpong/ping.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile.ping
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network'
| cd download/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/network/download/download.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qbackingstore'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qbackingstore'
| cd qclipboard/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qclipboard/qclipboard.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/download'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/download'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/touch/knobs'
| cd downloadmanager/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/network/downloadmanager/downloadmanager.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/touch/knobs'
| cd dials/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/touch/dials/dials.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qdeadlinetimer'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qdeadlinetimer'
| cd qelapsedtimer/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/kernel/qelapsedtimer/qelapsedtimer.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/ipc/localfortuneserver'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/ipc/localfortuneserver'
| cd localfortuneclient/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/ipc/localfortuneclient/localfortuneclient.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusabstractadaptor/qmyserver'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusabstractadaptor/qmyserver'
| cd qdbusabstractadaptor/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusabstractadaptor/qdbusabstractadaptor/qdbusabstractadaptor.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/pingpong'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/downloadmanager'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/downloadmanager'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/pingpong'
| cd dnslookup/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/network/dnslookup/dnslookup.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qclipboard'
| ( test -e Makefile.pong || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile.pong /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/dbus/pingpong/pong.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile.pong
| cd copier/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qclipboard/copier/copier.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[6]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qdir/10000'
| make[6]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qdir/10000'
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qelapsedtimer'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qelapsedtimer'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qdir'
| cd qeventdispatcher/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/kernel/qeventdispatcher/qeventdispatcher.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qdiriterator/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/io/qdiriterator/qdiriterator.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/dnslookup'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/dnslookup'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/touch/dials'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/touch/dials'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/touch'
| cd blockingfortuneclient/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/network/blockingfortuneclient/blockingfortuneclient.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qtestlib/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/qtestlib/qtestlib.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/ipc/localfortuneclient'
| make[4]: Nothing to be done for 'first'.
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/ipc/localfortuneclient'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/ipc'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/pingpong'
| cd json/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/json/json.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qdiriterator'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qdiriterator'
| cd complexpingpong/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/dbus/complexpingpong/complexpingpong.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qfile/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/io/qfile/qfile.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[6]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qclipboard/copier'
| make[6]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qclipboard/copier'
| cd paster/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qclipboard/paster/paster.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qeventdispatcher'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qeventdispatcher'
| cd qeventloop/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/kernel/qeventloop/qeventloop.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[2]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qtestlib'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/blockingfortuneclient'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/blockingfortuneclient'
| cd tutorial1/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/qtestlib/tutorial1/tutorial1.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd broadcastreceiver/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/network/broadcastreceiver/broadcastreceiver.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusabstractadaptor/qdbusabstractadaptor'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusabstractadaptor/qdbusabstractadaptor'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusabstractadaptor'
| cd qdbusabstractinterface/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusabstractinterface/qdbusabstractinterface.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[6]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qclipboard/paster'
| make[6]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qclipboard/paster'
| cd test/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qclipboard/test/test.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/json'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/complexpingpong'
| ( test -e Makefile.complexping || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile.complexping /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/dbus/complexpingpong/complexping.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile.complexping
| cd savegame/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/json/savegame/savegame.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qfile'
| make[5]: Nothing to be done for 'first'.
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qfile'
| cd qfileinfo/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/io/qfileinfo/qfileinfo.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qeventloop'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/broadcastreceiver'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/broadcastreceiver'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qeventloop'
| cd qmath/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/kernel/qmath/qmath.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd broadcastsender/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/network/broadcastsender/broadcastsender.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusabstractinterface'
| cd qpinger/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusabstractinterface/qpinger/qpinger.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/complexpingpong'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/complexpingpong'
| ( test -e Makefile.complexpong || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile.complexpong /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/dbus/complexpingpong/complexpong.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile.complexpong
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qtestlib/tutorial1'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qtestlib/tutorial1'
| cd tutorial2/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/qtestlib/tutorial2/tutorial2.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/json/savegame'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/json/savegame'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/json'
| cd mimetypes/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/mimetypes/mimetypes.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[6]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qclipboard/test'
| make[6]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qclipboard/test'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qclipboard'
| cd qcursor/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qcursor/qcursor.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/broadcastsender'
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qfileinfo'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qfileinfo'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/broadcastsender'
| cd qiodevice/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/io/qiodevice/qiodevice.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd http/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/network/http/http.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/mimetypes'
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusabstractinterface/qpinger'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusabstractinterface/qpinger'
| cd mimetypebrowser/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/mimetypes/mimetypebrowser/mimetypebrowser.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qdbusabstractinterface/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusabstractinterface/qdbusabstractinterface/qdbusabstractinterface.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/complexpingpong'
| cd chat/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/dbus/chat/chat.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qmath'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qmath'
| cd qmetaobject/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/kernel/qmetaobject/qmetaobject.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qcursor'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qcursor'
| cd qdrag/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qdrag/qdrag.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/http'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qtestlib/tutorial2'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qtestlib/tutorial2'
| linking http
| cd tutorial3/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/qtestlib/tutorial3/tutorial3.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qiodevice'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qiodevice'
| cd qtemporaryfile/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/io/qtemporaryfile/qtemporaryfile.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| .obj/main.o: file not recognized: File truncated
| collect2: error: ld returned 1 exit status
| Makefile:108: recipe for target 'http' failed
| make[3]: *** [http] Error 1
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network/http'
| Makefile:211: recipe for target 'sub-http-make_first' failed
| make[2]: *** [sub-http-make_first] Error 2
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/network'
| Makefile:181: recipe for target 'sub-network-make_first' failed
| make[1]: *** [sub-network-make_first] Error 2
| make[1]: *** Waiting for unfinished jobs....
| cd tutorial4/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/qtestlib/tutorial4/tutorial4.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusabstractinterface/qdbusabstractinterface'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusabstractinterface/qdbusabstractinterface'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusabstractinterface'
| cd qdbusconnection/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusconnection/qdbusconnection.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/chat'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/chat'
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/mimetypes/mimetypebrowser'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/mimetypes/mimetypebrowser'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/mimetypes'
| cd threads/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/threads/threads.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd remotecontrolledcar/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/dbus/remotecontrolledcar/remotecontrolledcar.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qmetaobject'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qmetaobject'
| cd qmetaobjectbuilder/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/kernel/qmetaobjectbuilder/qmetaobjectbuilder.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qtemporaryfile'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qtemporaryfile'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qtestlib/tutorial3'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qtestlib/tutorial3'
| cd qtextstream/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/io/qtextstream/qtextstream.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qdrag'
| cd tutorial5/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/qtestlib/tutorial5/tutorial5.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qdrag'
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qtestlib/tutorial4'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qtestlib/tutorial4'
| cd qevent/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qevent/qevent.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd tools/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/tools/tools.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/threads'
| cd semaphores/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/threads/semaphores/semaphores.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/remotecontrolledcar'
| cd car/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/dbus/remotecontrolledcar/car/car.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusconnection'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusconnection'
| cd qdbusconnection_no_app/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusconnection_no_app/qdbusconnection_no_app.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qmetaobjectbuilder'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qmetaobjectbuilder'
| cd qmetamethod/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/kernel/qmetamethod/qmetamethod.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/threads/semaphores'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/threads/semaphores'
| cd waitconditions/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/threads/waitconditions/waitconditions.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/tools'
| cd contiguouscache/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/tools/contiguouscache/contiguouscache.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qevent'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qevent'
| cd qfileopenevent/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qfileopenevent/qfileopenevent.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qtextstream'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qtextstream'
| cd qprocess/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/io/qprocess/qprocess.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[3]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qtestlib/tutorial5'
| linking tutorial5
| .obj/benchmarking.o: file not recognized: File truncated
| Makefile:105: recipe for target 'tutorial5' failed
| make[3]: *** [tutorial5] Error 1
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qtestlib/tutorial5'
| Makefile:148: recipe for target 'sub-tutorial5-make_first' failed
| make[2]: *** [sub-tutorial5-make_first] Error 2
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/qtestlib'
| Makefile:206: recipe for target 'sub-qtestlib-make_first' failed
| make[1]: *** [sub-qtestlib-make_first] Error 2
| cd mandelbrot/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/threads/mandelbrot/mandelbrot.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qprocess'
| cd testProcessLoopback/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/io/qprocess/testProcessLoopback/testProcessLoopback.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusconnection_no_app'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusconnection_no_app'
| cd qdbusconnection_no_bus/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusconnection_no_bus/qdbusconnection_no_bus.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/remotecontrolledcar/car'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/remotecontrolledcar/car'
| cd controller/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/dbus/remotecontrolledcar/controller/controller.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/threads/waitconditions'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/threads/waitconditions'
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qmetamethod'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qmetamethod'
| cd queuedcustomtype/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/threads/queuedcustomtype/queuedcustomtype.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qmetaproperty/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/kernel/qmetaproperty/qmetaproperty.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/tools/contiguouscache'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/tools/contiguouscache'
| cd customtype/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/tools/customtype/customtype.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qfileopenevent'
| cd test/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qfileopenevent/test/test.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[6]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qprocess/testProcessLoopback'
| make[6]: Nothing to be done for 'first'.
| make[6]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qprocess/testProcessLoopback'
| cd test/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/io/qprocess/test/test.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/threads/mandelbrot'
| linking mandelbrot
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusconnection_no_bus'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusconnection_no_bus'
| cd qdbusconnection_no_libdbus/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusconnection_no_libdbus/qdbusconnection_no_libdbus.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/remotecontrolledcar/controller'
| linking controller
| .obj/renderthread.o: file not recognized: File truncated
| Makefile:114: recipe for target 'mandelbrot' failed
| make[4]: *** [mandelbrot] Error 1
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/threads/mandelbrot'
| Makefile:97: recipe for target 'sub-mandelbrot-make_first' failed
| make[3]: *** [sub-mandelbrot-make_first] Error 2
| make[3]: *** Waiting for unfinished jobs....
| Makefile:115: recipe for target 'controller' failed
| make[4]: *** [controller] Error 1
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/remotecontrolledcar/controller'
| Makefile:70: recipe for target 'sub-controller-make_first' failed
| make[3]: *** [sub-controller-make_first] Error 2
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus/remotecontrolledcar'
| Makefile:148: recipe for target 'sub-remotecontrolledcar-make_first' failed
| make[2]: *** [sub-remotecontrolledcar-make_first] Error 2
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/dbus'
| Makefile:156: recipe for target 'sub-dbus-make_first' failed
| make[1]: *** [sub-dbus-make_first] Error 2
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qmetaproperty'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qmetaproperty'
| cd qmetatype/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/corelib/kernel/qmetatype/qmetatype.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/tools/customtype'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/tools/customtype'
| cd customtypesending/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/tools/customtypesending/customtypesending.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/threads/queuedcustomtype'
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/threads/queuedcustomtype/block.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/threads/queuedcustomtype/main.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/threads/queuedcustomtype/renderthread.cpp
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusconnection_no_libdbus'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusconnection_no_libdbus'
| cd qdbusconnection_spyhook/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusconnection_spyhook/qdbusconnection_spyhook.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[6]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qprocess/test'
| make[6]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qprocess/test'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io/qprocess'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/io'
| cd json/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/json/json.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[6]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qfileopenevent/test'
| make[6]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qfileopenevent/test'
| cd qfileopeneventexternal/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qfileopenevent/qfileopeneventexternal/qfileopeneventexternal.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qmetatype'
| linking tst_qmetatype
| .obj/tst_qmetatype.o: file not recognized: File truncated
| Makefile:105: recipe for target 'tst_qmetatype' failed
| make[5]: *** [tst_qmetatype] Error 1
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel/qmetatype'
| Makefile:314: recipe for target 'sub-qmetatype-make_first' failed
| make[4]: *** [sub-qmetatype-make_first] Error 2
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib/kernel'
| Makefile:56: recipe for target 'sub-kernel-make_first' failed
| make[3]: *** [sub-kernel-make_first] Error 2
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/corelib'
| Makefile:55: recipe for target 'sub-corelib-make_first' failed
| make[2]: *** [sub-corelib-make_first] Error 2
| make[2]: *** Waiting for unfinished jobs....
| cd mimetypes/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/mimetypes/mimetypes.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/tools/customtypesending'
| make[4]: Nothing to be done for 'first'.
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/tools/customtypesending'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/tools'
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/threads/queuedcustomtype/window.cpp
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/json'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/json'
| cd kernel/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/kernel/kernel.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[6]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qfileopenevent/qfileopeneventexternal'
| make[6]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qfileopenevent/qfileopeneventexternal'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qfileopenevent'
| cd qguieventdispatcher/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qguieventdispatcher/qguieventdispatcher.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/mimetypes'
| cd qmimedatabase/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/mimetypes/qmimedatabase/qmimedatabase.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusconnection_spyhook'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusconnection_spyhook'
| cd qdbuscontext/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbuscontext/qdbuscontext.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel'
| cd events/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/kernel/events/events.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbuscontext'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbuscontext'
| cd qdbusinterface/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusinterface/qdbusinterface.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguieventdispatcher'
| make[5]: Nothing to be done for 'first'.
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguieventdispatcher'
| cd qguieventloop/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qguieventloop/qguieventloop.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusinterface'
| cd qmyserver/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusinterface/qmyserver/qmyserver.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel/events'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel/events'
| cd qmetaobject/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/kernel/qmetaobject/qmetaobject.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/mimetypes/qmimedatabase'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/mimetypes/qmimedatabase'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/mimetypes'
| cd thread/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/thread/thread.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguieventloop'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguieventloop'
| cd qguimetatype/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qguimetatype/qguimetatype.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/thread'
| cd qmutex/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/thread/qmutex/qmutex.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusinterface/qmyserver'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusinterface/qmyserver'
| cd qdbusinterface/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusinterface/qdbusinterface/qdbusinterface.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel/qmetaobject'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel/qmetaobject'
| cd qmetatype/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/kernel/qmetatype/qmetatype.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguimetatype'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguimetatype'
| cd qguitimer/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qguitimer/qguitimer.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/thread/qmutex'
| linking tst_bench_qmutex
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusinterface/qdbusinterface'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusinterface/qdbusinterface'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusinterface'
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel/qmetatype'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel/qmetatype'
| cd qobject/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/kernel/qobject/qobject.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qdbuslocalcalls/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbuslocalcalls/qdbuslocalcalls.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| .obj/tst_qmutex.o: file not recognized: File truncated
| Makefile:103: recipe for target 'tst_bench_qmutex' failed
| make[5]: *** [tst_bench_qmutex] Error 1
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/thread/qmutex'
| Makefile:48: recipe for target 'sub-qmutex-make_first' failed
| make[4]: *** [sub-qmutex-make_first] Error 2
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/thread'
| Makefile:151: recipe for target 'sub-thread-make_first' failed
| make[3]: *** [sub-thread-make_first] Error 2
| cd qguivariant/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qguivariant/qguivariant.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguitimer'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguitimer'
| cd image/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/image.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguivariant'
| cd test/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qguivariant/test/test.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image'
| cd qimagereader/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qimagereader/qimagereader.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbuslocalcalls'
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbuslocalcalls/tst_qdbuslocalcalls.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel/qobject'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel/qobject'
| cd qvariant/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/kernel/qvariant/qvariant.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[6]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguivariant/test'
| make[6]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguivariant/test'
| cd no_application/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qguivariant/no_application/no_application.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel/qvariant'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel/qvariant'
| cd qcoreapplication/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/benchmarks/corelib/kernel/qcoreapplication/qcoreapplication.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qimagereader'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qimagereader'
| cd qicoimageformat/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qicoimageformat/qicoimageformat.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[6]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguivariant/no_application'
| make[6]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguivariant/no_application'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguivariant'
| cd qinputmethod/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qinputmethod/qinputmethod.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel/qcoreapplication'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel/qcoreapplication'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib/kernel'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks/corelib'
| Makefile:49: recipe for target 'sub-corelib-make_first' failed
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/benchmarks'
| Makefile:70: recipe for target 'sub-benchmarks-make_first' failed
| make[1]: *** [sub-benchmarks-make_first] Error 2
| make[1]: *** Waiting for unfinished jobs....
| cd qkeyevent/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qkeyevent/qkeyevent.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qicoimageformat'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qicoimageformat'
| cd qpixmap/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qpixmap/qpixmap.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qkeyevent'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qkeyevent'
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qpixmap'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qpixmap'
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qinputmethod'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qinputmethod'
| cd qimageiohandler/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qimageiohandler/qimageiohandler.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qkeysequence/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qkeysequence/qkeysequence.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qimage/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qimage/qimage.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qkeysequence'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qkeysequence'
| cd qmouseevent/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qmouseevent/qmouseevent.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qimage'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qimage'
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qimageiohandler'
| cd qimagewriter/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qimagewriter/qimagewriter.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qimageiohandler'
| cd qmovie/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qmovie/qmovie.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qmouseevent'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qmouseevent'
| cd qmouseevent_modal/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qmouseevent_modal/qmouseevent_modal.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qimagewriter'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qimagewriter'
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qmovie'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qmovie'
| cd qpicture/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qpicture/qpicture.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qicon/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qicon/qicon.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qmouseevent_modal'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qmouseevent_modal'
| cd qpalette/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qpalette/qpalette.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qpicture'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qpicture'
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qpalette'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qpalette'
| cd qscreen/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qscreen/qscreen.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qiconhighdpi/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qiconhighdpi/qiconhighdpi.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qscreen'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qscreen'
| cd qsurfaceformat/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qsurfaceformat/qsurfaceformat.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| generating .moc/moc_predefs.h
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/threads/queuedcustomtype/renderthread.h
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qicon'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/examples/corelib/threads/queuedcustomtype/window.h
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qicon/tst_qicon.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qsurfaceformat'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qsurfaceformat'
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qiconhighdpi'
| cd qtouchevent/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qtouchevent/qtouchevent.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| rcc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qiconhighdpi/tst_qiconhighdpi.qrc
| compiling .moc/moc_renderthread.cpp
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qiconhighdpi/tst_qiconhighdpi.cpp
| compiling .moc/moc_window.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qicon/tst_qicon.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qtouchevent'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qtouchevent'
| cd qwindow/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qwindow/qwindow.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| compiling .rcc/qrc_tst_qiconhighdpi.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qiconhighdpi/tst_qiconhighdpi.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qwindow'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qwindow'
| cd qguiapplication/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qguiapplication/qguiapplication.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguiapplication'
| Some of the required modules (qtConfig(private_tests)) are not available.
| Skipped.
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qguiapplication'
| cd qpixelformat/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qpixelformat/qpixelformat.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qpixelformat'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qpixelformat'
| cd qopenglwindow/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qopenglwindow/qopenglwindow.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qopenglwindow'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qopenglwindow'
| cd qrasterwindow/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qrasterwindow/qrasterwindow.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qrasterwindow'
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/kernel/qrasterwindow/tst_qrasterwindow.cpp
| linking tst_qdbuslocalcalls
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbuslocalcalls'
| cd qdbusmetaobject/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusmetaobject/qdbusmetaobject.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| linking tst_qicon
| linking queuedcustomtype
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusmetaobject'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusmetaobject/tst_qdbusmetaobject.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qiconhighdpi'
| cd qdbusmetatype/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusmetatype/qdbusmetatype.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusmetaobject/tst_qdbusmetaobject.cpp:644: Warning: Property declaration property has no READ accessor function or associated MEMBER variable. The property will be invalid.
| /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusmetaobject/tst_qdbusmetaobject.cpp:655: Warning: Property declaration property has no READ accessor function or associated MEMBER variable. The property will be invalid.
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusmetaobject/tst_qdbusmetaobject.cpp
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusmetatype'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/threads/queuedcustomtype'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib/threads'
| Makefile:123: recipe for target 'sub-threads-make_first' failed
| make[2]: *** [sub-threads-make_first] Error 2
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples/corelib'
| Makefile:56: recipe for target 'sub-corelib-make_first' failed
| make[1]: *** [sub-corelib-make_first] Error 2
| make[1]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/examples'
| Makefile:73: recipe for target 'sub-examples-make_first' failed
| make: *** [sub-examples-make_first] Error 2
| make: *** Waiting for unfinished jobs....
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusmetatype/tst_qdbusmetatype.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusmetatype/tst_qdbusmetatype.cpp
| linking tst_qrasterwindow
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel/qrasterwindow'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/kernel'
| cd math3d/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/math3d.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/math3d'
| cd qquaternion/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/qquaternion/qquaternion.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/math3d/qquaternion'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/qquaternion/tst_qquaternion.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/qquaternion/tst_qquaternion.cpp
| rcc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/image/qicon/tst_qicon.qrc
| rcc .rcc/qmake_qmake_immediate.qrc
| compiling .rcc/qrc_tst_qicon.cpp
| compiling .rcc/qrc_qmake_qmake_immediate.cpp
| linking tst_qicon
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image/qicon'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/image'
| cd painting/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/painting.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting'
| cd qpainterpath/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpainterpath/qpainterpath.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpainterpath'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpainterpath/tst_qpainterpath.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpainterpath/tst_qpainterpath.cpp
| linking tst_qdbusmetatype
| linking tst_qdbusmetaobject
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusmetatype'
| cd qpainterpathstroker/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpainterpathstroker/qpainterpathstroker.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusmetaobject'
| cd qdbuspendingcall/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbuspendingcall/qdbuspendingcall.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| linking tst_qquaternion
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpainterpathstroker'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpainterpathstroker/tst_qpainterpathstroker.cpp
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbuspendingcall'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbuspendingcall/tst_qdbuspendingcall.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/math3d/qquaternion'
| cd qvectornd/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/qvectornd/qvectornd.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpainterpathstroker/tst_qpainterpathstroker.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbuspendingcall/tst_qdbuspendingcall.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/math3d/qvectornd'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/qvectornd/tst_qvectornd.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/qvectornd/tst_qvectornd.cpp
| linking tst_qpainterpath
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpainterpath'
| cd qcolor/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qcolor/qcolor.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| linking tst_qpainterpathstroker
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qcolor'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qcolor/tst_qcolor.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpainterpathstroker'
| cd qbrush/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qbrush/qbrush.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qcolor/tst_qcolor.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qbrush'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qbrush/tst_qbrush.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qbrush/tst_qbrush.cpp
| linking tst_qdbuspendingcall
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbuspendingcall'
| cd qdbuspendingreply/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbuspendingreply/qdbuspendingreply.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbuspendingreply'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbuspendingreply/tst_qdbuspendingreply.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbuspendingreply/tst_qdbuspendingreply.cpp
| linking tst_qvectornd
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/math3d/qvectornd'
| cd qmatrixnxn/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/qmatrixnxn/qmatrixnxn.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/math3d/qmatrixnxn'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/qmatrixnxn/tst_qmatrixnxn.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/qmatrixnxn/tst_qmatrixnxn.cpp
| linking tst_qbrush
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qbrush'
| cd qregion/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qregion/qregion.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| linking tst_qcolor
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qcolor'
| cd qpagelayout/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpagelayout/qpagelayout.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qregion'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qregion/tst_qregion.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qregion/tst_qregion.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpagelayout'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpagelayout/tst_qpagelayout.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpagelayout/tst_qpagelayout.cpp
| In file included from ../../../../../include/QtTest/qtestcase.h:1:0,
| from ../../../../../include/QtTest/../../../git/src/testlib/qtest.h:45,
| from ../../../../../include/QtTest/qtest.h:1,
| from ../../../../../include/QtTest/QtTest:7,
| from /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/qmatrixnxn/tst_qmatrixnxn.cpp:29:
| /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/qmatrixnxn/tst_qmatrixnxn.cpp: In member function 'void tst_QMatrixNxN::optimize()':
| /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/math3d/qmatrixnxn/tst_qmatrixnxn.cpp:3012:47: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
| QCOMPARE(reinterpret_cast<Matrix4x4 *>(&m)->flagBits, flagBits);
| ../../../../../include/QtTest/../../../git/src/testlib/qtestcase.h:87:26: note: in definition of macro 'QCOMPARE'
| if (!QTest::qCompare(actual, expected, #actual, #expected, __FILE__, __LINE__))\
| linking tst_qdbuspendingreply
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbuspendingreply'
| cd qdbusreply/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusreply/qdbusreply.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusreply'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusreply/tst_qdbusreply.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusreply/tst_qdbusreply.cpp
| linking tst_qpagelayout
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpagelayout'
| cd qopenglconfig/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/qopenglconfig/qopenglconfig.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/qopenglconfig'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/qopenglconfig/tst_qopenglconfig.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/qopenglconfig/tst_qopenglconfig.cpp
| linking tst_qregion
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qregion'
| cd qpagesize/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpagesize/qpagesize.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| linking tst_qmatrixnxn
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpagesize'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpagesize/tst_qpagesize.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/math3d/qmatrixnxn'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/math3d'
| cd qopengl/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/qopengl/qopengl.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpagesize/tst_qpagesize.cpp
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/qopengl'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/qopengl/tst_qopengl.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/qopengl/tst_qopengl.cpp
| linking tst_qdbusreply
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusreply'
| cd qdbusservicewatcher/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusservicewatcher/qdbusservicewatcher.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusservicewatcher'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusservicewatcher/tst_qdbusservicewatcher.cpp
| linking tst_qpagesize
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusservicewatcher/tst_qdbusservicewatcher.cpp
| linking tst_qopenglconfig
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpagesize'
| cd qpainter/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpainter/qpainter.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/qopenglconfig'
| cd text/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/text.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text'
| cd qabstracttextdocumentlayout/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qabstracttextdocumentlayout/qabstracttextdocumentlayout.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpainter'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpainter/tst_qpainter.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qabstracttextdocumentlayout'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qabstracttextdocumentlayout/tst_qabstracttextdocumentlayout.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpainter/tst_qpainter.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qabstracttextdocumentlayout/tst_qabstracttextdocumentlayout.cpp
| linking tst_qopengl
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/qopengl'
| cd qfont/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qfont/qfont.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qfont'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qfont/tst_qfont.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qfont/tst_qfont.cpp
| linking tst_qabstracttextdocumentlayout
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qabstracttextdocumentlayout'
| cd qfontdatabase/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qfontdatabase/qfontdatabase.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qfontdatabase'
| rcc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qfontdatabase/testdata.qrc
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qfontdatabase/tst_qfontdatabase.cpp
| linking tst_qdbusservicewatcher
| compiling .rcc/qrc_testdata.cpp
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusservicewatcher'
| cd qdbustype/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbustype/qdbustype.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbustype'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbustype/tst_qdbustype.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qfontdatabase/tst_qfontdatabase.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbustype/tst_qdbustype.cpp
| linking tst_qfont
| linking tst_qdbustype
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qfont'
| cd util/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/util.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbustype'
| cd qdbusthreading/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusthreading/qdbusthreading.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| cd qdesktopservices/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qdesktopservices/qdesktopservices.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusthreading'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusthreading/tst_qdbusthreading.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qdesktopservices'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qdesktopservices/tst_qdesktopservices.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusthreading/tst_qdbusthreading.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qdesktopservices/tst_qdesktopservices.cpp
| linking tst_qfontdatabase
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qfontdatabase'
| cd qfontmetrics/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qfontmetrics/qfontmetrics.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qfontmetrics'
| rcc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qfontmetrics/testfont.qrc
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qfontmetrics/tst_qfontmetrics.cpp
| compiling .rcc/qrc_testfont.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qfontmetrics/tst_qfontmetrics.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpainter'
| cd qpdfwriter/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpdfwriter/qpdfwriter.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| linking tst_qdesktopservices
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpdfwriter'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpdfwriter/tst_qpdfwriter.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qdesktopservices'
| cd qdoublevalidator/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qdoublevalidator/qdoublevalidator.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpdfwriter/tst_qpdfwriter.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qdoublevalidator'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qdoublevalidator/tst_qdoublevalidator.cpp
| linking tst_qdbusthreading
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qdoublevalidator/tst_qdoublevalidator.cpp
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusthreading'
| cd qdbusxmlparser/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusxmlparser/qdbusxmlparser.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusxmlparser'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusxmlparser/tst_qdbusxmlparser.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/dbus/qdbusxmlparser/tst_qdbusxmlparser.cpp
| linking tst_qfontmetrics
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qfontmetrics'
| cd qglyphrun/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qglyphrun/qglyphrun.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qglyphrun'
| rcc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qglyphrun/testdata.qrc
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qglyphrun/tst_qglyphrun.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qglyphrun/tst_qglyphrun.cpp
| linking tst_qpdfwriter
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpdfwriter'
| cd qpen/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpen/qpen.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpen'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpen/tst_qpen.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpen/tst_qpen.cpp
| linking tst_qdoublevalidator
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qdoublevalidator'
| cd qintvalidator/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qintvalidator/qintvalidator.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qintvalidator'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qintvalidator/tst_qintvalidator.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qintvalidator/tst_qintvalidator.cpp
| linking tst_qpen
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpen'
| cd qpaintengine/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpaintengine/qpaintengine.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| linking tst_qglyphrun
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpaintengine'
| generating .moc/moc_predefs.h
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpaintengine/tst_qpaintengine.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qglyphrun'
| cd qrawfont/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qrawfont/qrawfont.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpaintengine/tst_qpaintengine.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qrawfont'
| rcc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qrawfont/testdata.qrc
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qrawfont/tst_qrawfont.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qrawfont/tst_qrawfont.cpp
| linking tst_qpaintengine
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpaintengine'
| cd qtransform/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qtransform/qtransform.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qtransform'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qtransform/tst_qtransform.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qtransform/tst_qtransform.cpp
| linking tst_qintvalidator
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qintvalidator'
| cd qregexpvalidator/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qregexpvalidator/qregexpvalidator.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qregexpvalidator'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qregexpvalidator/tst_qregexpvalidator.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qregexpvalidator/tst_qregexpvalidator.cpp
| linking tst_qdbusxmlparser
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus/qdbusxmlparser'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/dbus'
| cd qregularexpressionvalidator/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qregularexpressionvalidator/qregularexpressionvalidator.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qregularexpressionvalidator'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qregularexpressionvalidator/tst_qregularexpressionvalidator.cpp
| linking tst_qrawfont
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qregularexpressionvalidator/tst_qregularexpressionvalidator.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qrawfont'
| cd qstatictext/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qstatictext/qstatictext.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qstatictext'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qstatictext/tst_qstatictext.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qstatictext/tst_qstatictext.cpp
| linking tst_qtransform
| linking tst_qregexpvalidator
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qtransform'
| cd qwmatrix/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qwmatrix/qwmatrix.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qregexpvalidator'
| cd qshadergenerator/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadergenerator/qshadergenerator.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qwmatrix'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qwmatrix/tst_qwmatrix.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qwmatrix/tst_qwmatrix.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qshadergenerator'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadergenerator/tst_qshadergenerator.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadergenerator/tst_qshadergenerator.cpp
| linking tst_qregularexpressionvalidator
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qregularexpressionvalidator'
| cd qshadergraph/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadergraph/qshadergraph.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qshadergraph'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadergraph/tst_qshadergraph.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadergraph/tst_qshadergraph.cpp
| linking tst_qstatictext
| linking tst_qwmatrix
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qstatictext'
| cd qsyntaxhighlighter/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qsyntaxhighlighter/qsyntaxhighlighter.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qwmatrix'
| cd qpolygon/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpolygon/qpolygon.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qsyntaxhighlighter'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qsyntaxhighlighter/tst_qsyntaxhighlighter.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpolygon'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpolygon/tst_qpolygon.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qsyntaxhighlighter/tst_qsyntaxhighlighter.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/painting/qpolygon/tst_qpolygon.cpp
| linking tst_qshadergenerator
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qshadergenerator'
| cd qshadergraphloader/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadergraphloader/qshadergraphloader.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qshadergraphloader'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadergraphloader/tst_qshadergraphloader.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadergraphloader/tst_qshadergraphloader.cpp
| linking tst_qpolygon
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting/qpolygon'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/painting'
| cd itemmodels/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/itemmodels/itemmodels.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[4]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/itemmodels'
| cd qstandarditem/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/itemmodels/qstandarditem/qstandarditem.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/itemmodels/qstandarditem'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/itemmodels/qstandarditem/tst_qstandarditem.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/itemmodels/qstandarditem/tst_qstandarditem.cpp
| linking tst_qsyntaxhighlighter
| linking tst_qshadergraph
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qsyntaxhighlighter'
| cd qtextblock/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextblock/qtextblock.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qshadergraph'
| cd qstandarditemmodel/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/itemmodels/qstandarditemmodel/qstandarditemmodel.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextblock'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextblock/tst_qtextblock.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextblock/tst_qtextblock.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/itemmodels/qstandarditemmodel'
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/other/modeltest/modeltest.cpp
| linking tst_qtextblock
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextblock'
| cd qtextcursor/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextcursor/qtextcursor.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextcursor'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextcursor/tst_qtextcursor.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextcursor/tst_qtextcursor.cpp
| linking tst_qshadergraphloader
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qshadergraphloader'
| cd qshadernodes/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadernodes/qshadernodes.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qshadernodes'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadernodes/tst_qshadernodes.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadernodes/tst_qshadernodes.cpp
| linking tst_qstandarditem
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/itemmodels/qstandarditemmodel/tst_qstandarditemmodel.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/itemmodels/qstandarditem'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/other/modeltest/modeltest.h
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/itemmodels/qstandarditemmodel/tst_qstandarditemmodel.cpp
| compiling .moc/moc_modeltest.cpp
| cd qtextdocument/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextdocument/qtextdocument.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextdocument'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextdocument/tst_qtextdocument.cpp
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextdocument/common.h
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextdocument/tst_qtextdocument.cpp
| linking tst_qtextcursor
| linking tst_qshadernodes
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextcursor'
| compiling .moc/moc_common.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qshadernodes'
| cd qshadernodesloader/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadernodesloader/qshadernodesloader.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qshadernodesloader'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadernodesloader/tst_qshadernodesloader.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/util/qshadernodesloader/tst_qshadernodesloader.cpp
| cd qtextdocumentfragment/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextdocumentfragment/qtextdocumentfragment.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextdocumentfragment'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextdocumentfragment/tst_qtextdocumentfragment.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextdocumentfragment/tst_qtextdocumentfragment.cpp
| linking tst_qstandarditemmodel
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/itemmodels/qstandarditemmodel'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/itemmodels'
| cd qtextdocumentlayout/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextdocumentlayout/qtextdocumentlayout.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextdocumentlayout'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextdocumentlayout/tst_qtextdocumentlayout.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextdocumentlayout/tst_qtextdocumentlayout.cpp
| linking tst_qshadernodesloader
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util/qshadernodesloader'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/util'
| cd qtextformat/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextformat/qtextformat.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextformat'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextformat/tst_qtextformat.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextformat/tst_qtextformat.cpp
| linking tst_qtextdocument
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextdocument'
| cd qtextlist/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextlist/qtextlist.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| linking tst_qtextdocumentlayout
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextlist'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextlist/tst_qtextlist.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextdocumentlayout'
| cd qtextobject/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextobject/qtextobject.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextlist/tst_qtextlist.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextobject'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextobject/tst_qtextobject.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextobject/tst_qtextobject.cpp
| linking tst_qtextobject
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextobject'
| cd qtextscriptengine/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextscriptengine/qtextscriptengine.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| linking tst_qtextformat
| linking tst_qtextdocumentfragment
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextscriptengine'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextscriptengine/tst_qtextscriptengine.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextformat'
| cd qtexttable/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtexttable/qtexttable.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtextscriptengine/tst_qtextscriptengine.cpp
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextdocumentfragment'
| cd qinputcontrol/ && ( test -e Makefile || /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qinputcontrol/qinputcontrol.pro -qtconf /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/bin/qt.conf ) && make -f Makefile
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtexttable'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtexttable/tst_qtexttable.cpp
| make[5]: Entering directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qinputcontrol'
| moc /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qinputcontrol/tst_qinputcontrol.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qtexttable/tst_qtexttable.cpp
| compiling /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/git/tests/auto/gui/text/qinputcontrol/tst_qinputcontrol.cpp
| linking tst_qtextlist
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextlist'
| linking tst_qinputcontrol
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qinputcontrol'
| linking tst_qtextscriptengine
| linking tst_qtexttable
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtextscriptengine'
| make[5]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text/qtexttable'
| make[4]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui/text'
| make[3]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto/gui'
| make[2]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests/auto'
| Makefile:45: recipe for target 'sub-auto-make_first' failed
| make[1]: *** [sub-auto-make_first] Error 2
| make[1]: Leaving directory '/home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/build/tests'
| Makefile:98: recipe for target 'sub-tests-make_first' failed
| make: *** [sub-tests-make_first] Error 2
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /home/noahm1/var-fslc-yocto/build_x11/tmp/work/armv7at2hf-neon-mx6qdl-fslc-linux-gnueabi/qtbase/5.10.1+gitAUTOINC+6c6ace9d23-r0/temp/log.do_compile.9151)
ERROR: Task (/home/noahm1/var-fslc-yocto/sources/meta-qt5/recipes-qt/qt5/qtbase_git.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2803 tasks of which 2798 didn't need to be rerun and 2 failed.
NOTE: Writing buildhistory
Summary: 2 tasks failed:
/home/noahm1/var-fslc-yocto/sources/meta-qt5/recipes-qt/qt5/nativesdk-qtbase_git.bb:do_compile
Summary: There were 4 ERROR messages shown, returning a non-zero exit code.
noahm1@noahm1-Latitude-E6520:~/var-fslc-yocto/build_x11$
Thank you for your answer...
Maxime.
gusarambula
Hello Maxime,
Is this problem still present? The VAR-SOM-MX6 is manufactured and supported by Variscite so they may be able to provide further assistance.
mdouglas
I get the same error when building bitbake fsl-image-qt5-validation-imx for imx8mqevk
using repo init -u https://source.codeaurora.org/external/imx/imx-manifest  -b imx-linux-sumo -m imx-4.14.98-2.0.0_ga.xml:
Any hope for help from NXP, or should we be selecting a better-supported processor/manufacturer? One would think these would be nominally tested before being released...
Build Configuration:
BB_VERSION = "1.38.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "ubuntu-16.04"
TARGET_SYS = "aarch64-poky-linux"
MACHINE = "imx8mqevk"
DISTRO = "fsl-imx-wayland"
DISTRO_VERSION = "4.14-sumo"
TUNE_FEATURES = "aarch64"
TARGET_FPU = ""
meta
meta-poky = "HEAD:c9bd4984f8f471ca2c43052714f4413ba99cf171"
meta-oe
meta-multimedia = "HEAD:8760facba1bceb299b3613b8955621ddaa3d4c3f"
meta-freescale = "HEAD:27ca94f8a4336790ba117b4298566f6820e7e74c"
meta-freescale-3rdparty = "HEAD:82037216280a39957fb4272581637abec734ad50"
meta-freescale-distro = "HEAD:f7e2216e93aff14ac32728a13637a48df436b7f4"
meta-bsp
meta-sdk = "HEAD:be96d9721c3e8ce3b30de8b68720815511e92c4d"
meta-browser = "HEAD:75640e14e325479c076b6272b646be7a239c18aa"
meta-gnome
meta-networking
meta-python
meta-filesystems = "HEAD:8760facba1bceb299b3613b8955621ddaa3d4c3f"
meta-qt5 = "HEAD:d4e7f73d04e8448d326b6f89908701e304e37d65"
m_mansour
I have the same problem on iMX8qm.
do_compile of qtbase_git.bb is failing, the reason is not clear.
