MCUXpresso IDE v10.3.1 - SEGGER broken
amuresan
MCUXpresso IDE v10.3.1 [Build 2233] [2019-02-20]
When I double-click on SEGGER
This also happens on 10.3.0
java.lang.NullPointerException
at com.nxp.mcuxpresso.core.debug.support.segger.ui.JLinkDebuggerTab.setDefaults(JLinkDebuggerTab.java:268)
at org.eclipse.debug.ui.AbstractLaunchConfigurationTabGroup.setDefaults(AbstractLaunchConfigurationTabGroup.java:77)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationTabGroupWrapper.setDefaults(LaunchConfigurationTabGroupWrapper.java:248)
at org.eclipse.debug.internal.ui.launchConfigurations.CreateLaunchConfigurationAction.performAction(CreateLaunchConfigurationAction.java:80)
at org.eclipse.debug.internal.ui.launchConfigurations.AbstractLaunchConfigurationAction$1.run(AbstractLaunchConfigurationAction.java:107)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.debug.internal.ui.launchConfigurations.AbstractLaunchConfigurationAction.run(AbstractLaunchConfigurationAction.java:110)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog$2.runInternal(LaunchConfigurationsDialog.java:590)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog$2.run(LaunchConfigurationsDialog.java:573)
at org.eclipse.debug.ui.AbstractDebugView.doubleClick(AbstractDebugView.java:765)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:831)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.ui.internal.JFaceUtil.lambda$0(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:828)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1459)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1258)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:249)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:247)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:306)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4428)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4238)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3817)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationsDialog.open(LaunchConfigurationsDialog.java:1203)
at org.eclipse.debug.ui.DebugUITools$3.run(DebugUITools.java:629)
at org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDialogOnGroup(DebugUITools.java:637)
at org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDialogOnGroup(DebugUITools.java:570)
at org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(OpenLaunchDialogAction.java:82)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
howardg
This same situation - empty project in project explorer, and the null pointer exception - was an unwelcome greeting coming home from a long holiday. We need to face it that projects livingin the MCUXpresso world, as with its KDS predecessor, are living on borrowed time in an incredibly fragile tightly coupled dev environemnt. We're always on the edge of something breaking that'll eat half a week.  It's not you.
Points to NXP for at least providing a sort of cross platform IDE but all points come off because the breakage happens way too readily. I never have these problems in IAR or even with the bloated junit IDE for android development.
First you need to recover your workspace. Something toasted it. Hopefully you take frequent backups of the workspace.  If so you won't need to re-create the Segger config, it'll still be there.
lpcxpresso_supp
Can you clarify what you steps you are taking to start a debug session? From your screenshot, it actually appears like you have no projects in your workspace - which is definitely not right !
Please ensure that you have taken a look at the supplied MCUXpresso IDE v10.3 User Guide, for details of now to create projects (either by importing examples or using the new project wizard) and then how to use the Quickstart Panel to start a debug session for your project.
MCUXpresso IDE Support
