Demo Code for MPC57XXXMB / MPC574XG-MB
zilongduzun
Has the demo code for the MPC57XXXMB or MPC574XG-MB board been released yet? If so, where can I find it? And if not, when will it be released?
davidtosenovjan
Hi, I am not sure which demo code you have on your mind. You can look for instance following example repositories (search for MPC5748G):
MPC5 software example list
https://community.nxp.com/docs/DOC-335330
zilongduzun
thank you,I want to find some demo code about supporting HSM,where can I find it?
15/5000
I want to find some code about supporting hsm.
davidtosenovjan
I have asked colleagues as I don't have HSM knowledge and I can sum it to following.
There is HSM example code within the S32 design studio, SDK code.
1) HSM must be present on the device
2) HSM must be configured in DCF records
3) HSM Firmware must be present on the device
If not, the example in S32DS is not possible to run.
zilongduzun
OK,thank you for providing so much information.So are there any products or links about s32?
