We’re developing a prototype here that requires a sensor with the characteristics of the above but with a pressure spec of 20, or more, PSI.
In that regard, I’m looking for alternatives that might suit as any that Honeywell have are back-ordered.
I would be grateful if you could check if NXP stock one such – thank you.
Spec on page 5 page https://sensing.honeywell.com/honeywell-sensing-basic-board-mount-pressure-abp-series-datasheet-2305...
Hi Jerome,
First off, thank you for your interest in NXP's pressure sensors!
Looking at the spec, I assume the closest one is the MPX4250DP:
https://www.nxp.com/docs/en/data-sheet/MPX4250D.pdf
However, it is a completely different package (Unibody, through-hole) and not compatible with liquids.
For more options, have a look at Differential/Gauge up to 1000 kPa | NXP.
Tomas
