Imx.6dq opens the original system camera, video playback shows green screen, using Camera. Preview Callback interface callback byte [] data shows green screen, how to solve this problem? Have you ever encountered this problem? Ask for advice?
hi
Now open the system camera application preview normal, video playback display screen, as well as in their own applications call Camera. Preview Callback interface callback method of frame data, saved as a suffix named YUV format file display green screen, what is the cause? Is it related to the coding format?
These are the video files of the video floral screen and the files that hold a data image.
Hi 弘毅 刘
green screen may be caused if there are some hardware problems:
no signal from camera or wrong connections. One can check camera signals
with oscilloscope.
