Errors in Accesing EMIOS registers to set channel frquency , period and CAN in MPC5777c
vignesh_v
  im facing compilation errors in accessing registers to set emios registers for setting values. i took from example codes and tried to modify but it seems that example code has old register definitions and t throws error. Can someone guide me how to acess the registers for EMIOS Operation and CAN operations without errors.
EMIOS_0.CH[0].CADR.R = 250;
EMIOS_0.CH[0].CBDR.R = 1;
Same for CAN
CAN_B.BUF is not present.
