MFG tool make image file from board and save on pc
cyndent
Hi, i want to use mfgtool to get image from my device.My device use emmc not sd card.
The mfgtool put kernel and uboot to memory and run. And i have succeed to burn image to my device.
And now i want to get the image back to make a factory image.Is it possiable to use dd command make image from boot to pc only use mfgtool.I find there is command pull but no enough information about pull and dd command.
Thanks!
Labels (3)
jimmychan
mfgtool cannot dump the image back from board to pc. I think you can boot your board using NFS. Then the emmc will be a device mmcblk (e.g. mmcblk0 or mmcblk1). Then you can use 'dd' to dump your image from emmc to a file.
Hi Mingyang
I am afraid currently such option is not available with mfg tool, in general
one can try to add such functionality using its sources:
GitHub - NXPmicro/mfgtools: Freescale/NXP I.MX Chip image deploy tools.
