PCF8576C
Question asked by Kebron Welday on Feb 25, 2019
Latest reply on Feb 27, 2019 by G.w. Sun
I'm working with a single PCF8576C and I'm not sure where to connect the CLK and SYNC pin in static mode.
The datasheet says that those pins should be at a defined level(Vss or Vdd).
I'm using the internal oscillator of the PCF8576C that means I get an output clock signal from CLK for cascaded PCF8576. Can I simply pull both pins up ?
Thanks in advance!
