MCUXPresso Setting, Searching didn't work
kevin_lang
I tried different version from v10.0.2  to v10.3.1 , all search doesn't work
And Project setting has no effect ,
Once I clicked Apply and Close, it shows like this and doesn't generate .bin file
Thanks for your help in advance
Kevin
lpcxpresso_supp
I've never seen or heard of anything similar before. Can you try switching the IDE to run with a completely new workspace? That should effectively reset the search history contents, which should hopefully clear your problem.
MCUXpresso IDE Support
lpcxpresso_supp
There are no known issues with these items of functionality, and in particular the Search menu is completely standard Eclipse - not something we change.
However can you explain exactly what you are doing? All of the screenshots you included in your original post appear to have snippets of other areas of the IDE's screen display embedded inside them, rather than text?
kevin_lang
Thank you so much for quick response
On my computer, Once I click MCUXpresso IDE Search menu, it shows all fields filled with something else, and I can't input anything, fields are not allowed to input
Kevin
