Trap error
Trap error
qidongli
I use JN-AN-1218-Zigbee-3-0-Light-Bulb smaple compile occur error message:
!!! Trap error
u32PICMR = 0 : u32PICSR = 8000
u32PICMSR = 0 : u32IPMR = 0
u32IHPR = c : u32AINT = 8000 u32PINT 0
EPCR = b3f60 : EEAR = 9cffefff
In Application I use eZLO_RegisterOnOffLightEndPoint() function register four application endpoint,then,download program to evaluation boards, occur above error message, how to solve this problem,And without changing the requirements!
Thanks!
mario_castaneda
Could you please provide the AN and the SDK version that you are working on?
Mario
qidongli
The ZStack SDK Version is JN-SW-4170 Zigbee 3.0 v1840, The Project sample is JN-AN-1218-Zigbee-3-0-Light-Bulb. You have ways solve this question?
mario_castaneda
Did you try the example with any modification?
Could you please provide what did you modify?
Mario
