MBDT for mpc574x can not run.
hongjinzeng
Hi everyone,
      Today,I install the MBDT for mpc574x. According to the indicate, I generate the lic file.Then I open the gpio_mpc574x.mdl,click the build button,the error appearance.Can you help me solve the problem?
constantinrazva
Hello hongjinzeng‌,
Can you open a command prompt on your computer and run the following command
vol
and tell us if the Volume Serial Number matches the one from the license file?
(this is from license.dat file)
Kind regards,
Razvan.
constantinrazva
Hello hongjinzeng‌,
vol
Kind regards,
Razvan.
hongjinzeng
sorry, the Volume Serial Number is different.
constantinrazva
I was just about to point that out - try generating the license again and come back here if you still face issues.
Kind regards,
Razvan.
hongjinzeng
After I add the MBDT lic file's address to the environment variables like this    LM_LICENSE_FILE = C:\Users\ZengHongJing\AppData\Roaming\MathWorks\MATLAB Add-Ons\Toolboxes\NXP_MBDToolbox_MPC57xx\lic\license.lic
The project build successful.
constantinrazva
Hello hongjinzeng‌,
I will investigate why this is happening - but thank you for letting us know about this workaround.
Kind regards,
Razvan.
hongjinzeng
I try to generate the license again,but the issuse also remain.
hongjinzeng
The Volume Serial Number is same ,but also the error will appearance.
