Does anybody knows how should I get the Power Supply voltage to UJA1132 in a system with more than 20V.
The chip type number is UJA1132HW/5V0. It has two pins to detect battery voltage BAT and BATSENSE, the max voltage it can detect is 20V in the datasheet.
if I use UJA1132 in a 24V system, how should I get the battery voltage.
1) Using resister dividing network and connecting to BATSENSE will causevoltage sensor error.
2) Should I use resister dividing network and also a follower circuit(with an operational amplifier). Will this method can solve the problem.
3) Is there any other good solutions?
Also reply to you in your case ticket!
