Hello:
We make a new project with 1052 to connect traditional external sram memory chip. But based on manual reference, can not find WE and OE pin connect to 1052 semc, only SEMC_WE for SDRAM only.
However, in the reference still write above:
Please tell me how to connect the SEMC and SRAM interface.
In the Reference Manual, you find the section "24.4.3 Pin Mux in SEMC" the table.
So SEMC_WE is only used for SDRAM, for SRAM you have to use the SEMC_ADDR11
Hope this helps
