Rapid IoT App issue
Rapid IoT App issue
sunnywu
my Rapid IoT App sometimes can correct connect, sometimes it always remind me error 567199086.jpg
richard_laborde
Please verify which version of the App you are using. 1.2.3 is the latest, older versions may not connect reliably.
sunnywu
yes, I had update the app to the latest version 1.2.3, but the issue is still exist.
estephania_mart
Which version of Android are you using ? Are you deleting the old connections ? If you delete the old connections do you still have the issue ?
Estephania
