MKM14Z64ACHH5 Is the mass-erase function implemented?
jun1
Contributor V
Hi.
kinetis-KM series MKM14Z64ACHH5 Is the mass-erase function implemented?
As IAR's EWARM flash loader option setting does not enable mass flashing before flash writing, I was worried that the device does not have that function.
Thank you.
miduo
Sorry for the late response.
Answer to your question, the mass-erase function surely implemented. Do not worry. You may do like below:
jun1
Contributor V
thank you for your answer.
OK. It was good.
miduo
