Hi Daniel,
Thank you for your answer. The application consist of a CAN Loader , therefore, I am placing my code in a secure memory segment, however, some libraries are being called and I don't know how to control the use of these libraries or its placement.
I used __OPTIMIZE_FOR_TIME__ ; instruction but the call to runtime routine is still there (LCMP_RC).
If there is no way to get around the JUMP generated by the compiler, maybe the way to get this work done is by controlling the memory segment in which the routine is placed.
I'd rather eliminate the JUMP instead of placing it in safe memory but I don't know if it is possible.
Jaime
