I wrote a library function, compiled with gcc to generate .a and .so library files, found that can not be used in the s23v234 environment, how to compile in order to use under s32v?
Solved! Go to Solution.
it seems this prooblem has been solved. the library must be rebuild under the s32v environment because the gcc version under s32v is different from gcc under linux os.
what is your gcc version and operating system?
Jiri
