LPC845 sampling time
pasqualebarrega
Good morning, I'm working with an LPC845 microcontroller.
For a specific application I need to know how many TAD implies the sampling process of the A/D converter over the entire conversion time.
I have searched on user manual and datasheet but I haven't found any data about sampling except for the total conversion time that is equal to 25 TAD.
Thank you in advance.
Best regards.
Pasquale Barrega.
kerryzhou
Hi Pasquale Barrega,
     The LPC845 didn't provide the other sample time, you can consider the full conversion time as the sample time.
So, if your ADC clock is the maximum data 30Mhz, then you will get the max conversion rate or sample rate 1.2Msample/s.
Wish it helps you!
Kerry
kerryzhou
   Could you give me the full name of TAD?
Kerry
pasqualebarrega
Il 2019-02-20 12:21 kerryzhou ha scritto:
NXP COMMUNITY
RE: LPC845 SAMPLING TIME
reply from Kerry Zhou in LPC Microcontrollers - View the full
discussion
