System clock frequency configuration for Kinetis KV10 MCU's
Question asked by MOH BENDER on Feb 18, 2019
Latest reply on Feb 19, 2019 by Marius Lucian Andrei
By default the system clock frequency for kinetis KV10 MCU's is 75 MHz.
Could you please tell me if there is a possibility to configure the system clock frequency (use another value instead of 75) ? configuration with PLL for example ?
In FreeMaster, is it possible to have access to the system clock ? if yes, which variable i need to check?
Thanks in advance for your support
