WS2812B on JN5168
WS2812B on JN5168
joerg_bernau
Hi together,
I want to connect WS2812B to a JN5168 module. I never coded DMA, but I read that this migbt be the best solution for asymetric signal generation. Is it possible with JenOS?
What is the best approach? Any suggestions are welcome.
Best Greetings
Joerg
mario_castaneda
Hi Joerg,
You can control the WS2812B, with the JN5168 device.
Note: You should take care of the current that WS2812B requires and if you need an extra circuit to protect the MCU.
I recommend the PWM implementation, please look at the JN-AN-1218, the dimmable light example.
Mario
joerg_bernau
Hi Mario,
I found my Solution at JN-AN-1166.
Best Regards joerg
