When I read PCI-0 physical address 0xf80000000(PCI-0 have no target device present) on T2080RDB(T2080E rev1.0) the CPU will hang and can not get CPU information from codeWarrior(codeWarrior report protocol error).
But on other T2080RDB(T2080E rev1.1), the read access will not make CPU hang.
who can explain it?
What is the correct CPU response when accessing 0xf80000000? trigger a machine check? data storage?
It is normal that Machine Check is generated when a PCIe read transaction addressed memory region assigned to a target device which is not present.
In this case no valid data can be returned, so asynchronous Machine Check is generated.
What is mapped to this address?
Please provide U-Boot booting log.
Hello ufedor
I am having machine check issue too. Can you take a look this thread https://community.nxp.com/thread/522267
Thanks.
