CodeWarrior Classic EVAL - flex
stephen_george
Trying to EVALUATE the legacy CodeWarrior classic edition ( 6.3 ) and would like to test the flex licensing situation.
However I read through the FLEX setup guide, but when I try to generate the license for the EVAL version it does not offer me the page (and fields) to enter Server ID or FLEX ID while generating license.
I would like to test this setup, as our this version has to run on WinXP inside a virtual machine, so want to test flex licensing solution works before paying to flex license
Steve
TomasPaez
Evaluation licenses do not need a dongle nor Server set up.
Evaluation license file are used in client base mode , this means the license file will work locally wit no need of external hw such dongle or server.
if you want to evaluation please go to the next page
https://www.nxp.com/support/developer-resources/software-development-tools/codewarrior-development-t...
if you would like to test a more specific scenario such as dongle based or server based create a support case in www.nxp.com/support
