Starting development with RapidIOT kit and MCUXpresso IDE
ujjwalrathod007
Hello all,
I have a question about how I could start developing code for RapidIOT Kit with Xpresso IDE?
I saw some of the examples on Rapid IOT studio which had imported modules/Elements in them. Is it possible for us to create custom user-defined modules in IDE which can be imported in IOT studio?
Tags (2)
mario_castaneda
Hi Ujjval,
Please look at the next community post
RAPID-IOT MCUXPRESSO EXAMPLES PROJECTS
Getting Start with Rapid IoT Kit on MCUXpressoIDE
SLN-RPK-NODE-UG
You could add a custom module in the IOT studio, but it will require a library from the atmosphere format.
You can work in the MCUXpresso  taking a reference an example from the IOT studio
Mario
ujjwalrathod007
Thanks Mario,
That looks quite helpful. By the way I had a look at several online resources and tried to figure out and found that I have to use something like SDK. I chose the SDK. I hope it is with the right configuration. because when I donloaded there were many development boars listed out of which Rapid IOT Kit was not there but the MCU Kinetic K64 was somehow there... I opt for that and got the SDK..
Next thing was to drag and drope the SDK in the MCUXpresso IDE>/..  I could not find the Install SDK view in the IDE, Though I see the next step import sdk example but that would be useless without the first step..
frq05186
The right SDK can be downloaded here:
https://www.nxp.com/webapp/Download?colCode=SLN-RPK-NODE-SDK&appType=license
Depending on your MCUXpresso version, you can drag and drop or import the SDK (right click in SDK window section)
