Well, I tried searching for the answer to this, but did not find anything. How do I delete a project from Code Warrior? I can make new ones just fine, but I cannot get rid of some that I no longer need. How do I do it?
First, check that the lingering projects are not designated as the default project (Project > Set Default Project). Then delete the directories generated by CodeWarrior when you first made the project.
