mcp5777c SPWM without Etpu API
aadeshmukh5
hi, i am working on mcp5777c , genrating spwm using etpu API's . can you tell me is there any other way of genrating spwm without using API's
davidtosenovjan
Hi, could you clarify what exactly you would like to do? How to use eTPU I have briefly described for instance here:
https://community.nxp.com/thread/450945
If you ask whether eTPU can be used without its API, then an answer is no, it cannot. Always it must be prepared certain SW interface between host (CPU) and eTPU.
aadeshmukh5
hi david,
i want to generate spwm  using interrupt, for mcp5777c. can you please help me for this, thanks in advance.
aadeshmukh5
thanks a lot david
