Internal Pullup Issue in MPC5744P
hityouxinxin
Hello:
   There is a question when I use MPC5744P,I want to use internal pullup on PB[13],but I failed.
   When I try to set PUE and PUS bit in MSCR register,it always 0.In RM,I found this table,the NA means PB[13] could not using internal PUS?
petervlna
yes, that is correct. On B[13] there is no pulup available as table 4-16 describes.
As you can see it is connected to ADC1_AN[0] channel by default.
regards,
Peter
petervlna
regards,
Peter
