Re: linux usbotg vbus regulator device tree
christoph8446
Hi Igor,
Thanks for your reply! Can you explain why do I need the vbus-supply and the vbus1-regulator?
Chris
Yuri
  i.MX 6OTG_VBUS signals are needed for proper USB operation, since they are
used either as inputs for LDO_USB supply or for USB VBUS voltage detector.
Yuri.
