imx7 usb host port connect to one external LTE modem, sometime the LTE USB CDC ethernet port can drop. the dmesg log as here:
usb 1-1: USB disconnect, device number 5
cdc_ether 1-1:1.0 wwan0: unregister 'cdc_ether' usb-ci_hdrc.1-1, Mobile Broadband Network Device
cdc_ether 1-1:1.4 wwan1: unregister 'cdc_ether' usb-ci_hdrc.1-1, Mobile Broadband Network Device
usb usb1-port1: cannot reset (err = -32)
usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
usb usb1-port1: unable to enumerate USB device
what the root cause the error?
Hi Kang,
We are also facing the same issue, can you please let us know how did you resolved this issue, any input can help us a lot.
Thanks in advance.
Hi kang
in general your assumption may be correct, reason may be weak/noisy signal
due to cable or insufficient power supply. For modem one can check that usb cable
was not near antenna output and was sufficiently shielded. One can try to use
usb hub with external power supply.
