I started out using the MCUXpresso IDE.
I would build the SDK (WIndows/MCUX)
Import the SDK into the IDE
Use the wizard to use the SDK to build a project with the drivers and middleware I need.
That went fine.
Now I need to do the same thing for GCC/Make.
I built the SDK (WIndows/GCC)
Are there any tools to use the SDK to make a GCC project?
What about IAR or Keil?
Tom
Hi Tom,
something like this:
Tutorial: Makefile Projects with Eclipse | MCU on Eclipse
I hope this helps,
Erich
