layout file for QN9080 eval board
dany_james
hello, we are working with QN9080 eval board, the layout (.brd ) that you have provided in your site is giving an error "line 1, column 1: Start tag expected", can you please provide the correct file ?
estephania_mart
Which tool are you using to try to open it? The files provided were generated in OrCAD and have that format, those are the only format that we provide for the files. If you are using another tool you might need to convert the files in case it is possible.
Estephania
lepol
Hi I got this error when opened with Eagle. Didn't know that two design studios are creating board layout with same file extension.
