Is SPL image support NOR flash?
vinothkumars
Senior Contributor IV
Hi All.
I am working on T4160RDB. I built u-boot-spl.bin and flash using NOR. But, I have a doubt, is it SPL really work in NOR?
or is SPL image suitable for NAND and SDcard?
VinothS
Vinothkumar Sekar
ufedor
SPL executed from SRAM is required for SD and NAND boot because direct code execution from these devices is not possible - it is required to read block of data to SRAM and execute it from there.
ufedor
vinothkumars
Hi Ufedor,
Thank you for your reply.
So, there is no possible to use SPL binary for NOR flash.
Is it right ?
VinothS
Vinothkumar Sekar
ufedor
Yes.
vinothkumars
Thank you
Vinothkumar Sekar
