Using the NXP for CAN signals
vssaini
Does anyone know what kind of CAN data does the FCAN module output in simulink?
constantinrazva
Hello vssaini@edu.uwaterloo.ca‌,
The CAN receive block outputs data of uint8 type
You can click on the block to open the mask, then click on Help to get more information on all blocks from our toolbox.
Kind regards,
Razvan.
vssaini
Hi Constantin,
Thanks for this. I also want to use the vehicle network toolbox that comes with simulink to unpack the CAN messages the FCAN receive will output. Would you happen to know what type of CAN signal the vehicle network toolbox takes as input?
