Boot Image Layout in IMX8DQXP
Question asked by Muthusubramanian Vengataraman on Feb 6, 2019
Latest reply on Feb 15, 2019 by sureshrao
I am referring to the IMX8DQXPRM.pdf document Figure 5-25 Typical Boot Image Layout.
Header 1Header 2
Primary Image Container Set
1st Container Header (SECO FW)
1st Signature Block
Padding for 1KB alignment
2nd Container Header (SCFW + M4 + AP)
2nd SIgnature Block
SECO FW
SCU FW with DDR initialization image embedded
CM4 Image
AP IPL
Secondary Image Container Set
My assumption is that the Secondary Image Container Set will also have
   1st Signature Block
   2nd SIgnature Block
   SECO FW
   CM4 Image
   AP IPL
And this Secondary Image Container Set starts at an offset specified in the eFUSE Row index 720 against the Image Container Set1 Offset location. Is that correct?
My question is
1. Is it possible to create a single binary file from the mkimage_imx8 with both image container sets present in it adhering to the above boot image layout.
         a. If yes what should be the command to invoke the mkimage_imx8.
         b. If no then how we should generate the binaries matching the above boot image layout.
V.Muthusubramanian
