Can a Connection fail due to lost packets?
Question asked by Daniele Nava on Feb 6, 2019
Latest reply on Feb 8, 2019 by Mario Ignacio Castaneda Lopez
I'm currently working on an application where a master has to connect to a slave.
The slave is advertising with undirected, connectable advertises.
At some point, the master application will ask for a connection to the slave.
Is there a possibility that the procedure does not succeed (maybe some packets during the validation are lost)?
I'm excluding the cases
- the slave request a disconnect
- after the connection procedure is completed, the slave goes out of range and therefore, the connection timeout trigger a disconnection.
Thank you
