Alexandre Bensi
How to disable extern RESET(PTA5) on the HCS08
Discussion created by Alexandre Bensi on Feb 6, 2019
Hello!
I have disabled RSTPE with SOPT1 = 0, but PTA5 GPIO still reset the microcontroller when it was to low level.
Please, Can anyone please help me to understand this behaviour?
This is my source code to set it:
void main(void)
     asm
          ldhx   #$83F;#__SEG_END_SSTACK ;
          txs;
     }     // Inicializa Stack Pointer.
// Inicializa Valores na RAM.
asm
     ldhx     #$40
res:
     //sta          SRS
     clr     ,x
     aix     #1
     cphx     #$0800
     bcs          res
     nop
// Configura periféricos.
     /* WDOG_CNT: CNT=0xC520 */
     WDOG_CNT = 0xC520U;         /* First part of the WDG unlock sequence */
     /* WDOG_CNT: CNT=0xD928 */
     WDOG_CNT = 0xD928U;         /* Second part of the WDG unlock sequence */
     /* WDOG_TOVAL: TOVAL=4 */
     WDOG_TOVAL = 0x04U;
     /* WDOG_CS2: WIN=0,FLG=0,??=0,PRES=0,??=0,??=0,CLK=1 */
     WDOG_CS2 = 0x11U;
     /* WDOG_CS1: EN=0,INT=0,UPDATE=0,TST=0,DBG=0,WAIT=0,STOP=0 */
     WDOG_CS1 = 0x81U;            /* Disable watchdog */
     PORT_PTAOE=0b00001100;     // Seleciona Saídas PortA
     PORT_PTBOE=0b00010010;     // Seleciona Saídas PortB
     PORT_PTCOE=0b00001111;     // Seleciona Saídas PortC
     PORT_PTDOE=0b00000000;     // Seleciona Saídas PortD
     PORT_PTAIE=0b00100010;     // Seleciona Entradas PortA
     PORT_PTBIE=0b11000101;     // Seleciona Entradas PortB
     PORT_PTCIE=0b01000000;     // Seleciona Entradas PortC
     PORT_PTDIE=0b00000000;     // Seleciona Entradas PortD
     PORT_PTAPE=0b00100000;     // Pullup PortA
     PORT_PTBPE=0b11000101;     // Pullup PortB
     PORT_PTCPE=0b00000000;     // Pullup PortC
     PORT_PTDPE=0b01000000;     // Pullup PortD
     ICS_C2=0x00;     //
     ICS_C1=0x04;     //
     ICS_C3 = *(char*)0xFF6FU;                           /* Initialize ICS_C3 register from a non volatile memory */
     ICS_C4 = (char)((*(char*)0xFF6EU)&(char)0x01U);     /* Initialize ICS_C4 register from a non volatile memory */
// Habilita Clocks dos periféricos.
     SCG_C1=0b10100010;
// Configura MTIM para Gerar interrupção periódica
     MTIM0_MOD     =     0;
     MTIM0_CLK     =     0b00000110;     //
     MTIM0_SC     =     0b01000000;     //
// Acerta a multiplexação dos pinos aos periféricos.
     SYS_SOPT1     =     0b10001100;     // RSTPE=0
     SYS_SOPT3     =     0b01000000;     //
     //FTM0_C0SC     =     0b00111000;     // FTM0 como contador de tempo para
     FTM0_SC          =     0b00001011; // recepção de RF.
     FTM0_MOD     =     0;               //
// Configura FTM2 como PWM para os Led´s.
     FTM2_C0SC     =     0b00111000;          // PWM Led
     FTM2_C1SC     =     0b00111000;          // PWM Led
     FTM2_C2SC     =     0b00111000;          // PWM Led
     FTM2_SC          =     0b01001011;          //
     FTM2_MOD     =     1000;               // Contagem Máxima do Timer.
     FTM2_C0V     =     0;                    // Ciclo ativo Led
     FTM2_C1V     =     0;                    // Ciclo ativo Led
     FTM2_C2V     =     0;                    // Ciclo ativo Led
// Configura Conversor A/D.
     ADC_APCTL2     =     0b00000000;     //
     ADC_APCTL1     =     0b10000000;     // Entradas analógicas
     ADC_SC3          =     0b01111001;     //
     ADC_SC2          =     0b00000000;     //
     ADC_SC1          =     0b00100111;     //
     NVM_FCLKDIV     = 0x07;
     DisableInterrupts;
     __RESET_WATCHDOG();          /* feeds the dog */
     EnableInterrupts;
