Problems occurred when invoking code from plug-in: "org.eclipse.jface"
Question asked by Victor Alastrue on Feb 5, 2019
Latest reply on Feb 8, 2019 by CarlosCasillas
Hi there,
I am trying to configure MCUXpresso for building FreeRTOS applications for ARM Cortex-M4 on i.MX7 following the indications in Tutorial: Building FreeRTOS Applications for ARM Cortex-M4 on i.MX7 with Eclipse | MCU on Eclipse .
Everything seems to work fine when MCUXpresso runs on Windows 10. However, I get the error below when I try to configure the project settings when running on Ubuntu 18.04.
Having a look to the .log file, I find the following:
!ENTRY org.eclipse.jface 4 2 2019-02-05 15:23:58.653
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.IllegalArgumentException: Argument not valid
    at org.eclipse.swt.SWT.error(SWT.java:4514)
    at org.eclipse.swt.SWT.error(SWT.java:4448)
    at org.eclipse.swt.SWT.error(SWT.java:4419)
    at org.eclipse.swt.widgets.Widget.error(Widget.java:487)
    at org.eclipse.swt.widgets.TabItem.setControl(TabItem.java:291)
    at org.eclipse.cdt.ui.newui.AbstractPage$InternalTab.createOn(AbstractPage.java:207)
    at org.eclipse.cdt.ui.newui.AbstractPage.handleMessage(AbstractPage.java:1246)
    at ilg.gnumcueclipse.managedbuild.cross.arm.ui.TabToolchains.handleTabEvent(TabToolchains.java:1134)
    at org.eclipse.cdt.ui.newui.AbstractPage.forEach(AbstractPage.java:1062)
    at org.eclipse.cdt.ui.newui.AbstractPage.cfgChanged(AbstractPage.java:1013)
    at org.eclipse.cdt.ui.newui.AbstractPage.handleConfigSelection(AbstractPage.java:472)
    at org.eclipse.cdt.ui.newui.AbstractPage.populateConfigurations(AbstractPage.java:804)
    at org.eclipse.cdt.ui.newui.AbstractPage.setVisible(AbstractPage.java:830)
    at org.eclipse.jface.preference.PreferenceDialog.showPage(PreferenceDialog.java:1260)
    at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.showPage(FilteredPreferenceDialog.java:591)
    at org.eclipse.jface.preference.PreferenceDialog$5.lambda$0(PreferenceDialog.java:657)
    at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
    at org.eclipse.jface.preference.PreferenceDialog$5.selectionChanged(PreferenceDialog.java:654)
    at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:872)
    at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
    at org.eclipse.ui.internal.JFaceUtil.lambda$0(JFaceUtil.java:44)
    at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
    at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java:869)
    at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect(StructuredViewer.java:1238)
    at org.eclipse.jface.viewers.StructuredViewer.lambda$0(StructuredViewer.java:1261)
    at org.eclipse.swt.events.SelectionListener$1.widgetSelected(SelectionListener.java:81)
    at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(OpenStrategy.java:261)
    at org.eclipse.jface.util.OpenStrategy.access$5(OpenStrategy.java:256)
    at org.eclipse.jface.util.OpenStrategy$1.lambda$1(OpenStrategy.java:426)
    at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:37)
    at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
    at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4577)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4186)
    at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
    at org.eclipse.jface.window.Window.open(Window.java:794)
    at org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDialogAction.java:157)
    at org.eclipse.ui.internal.ide.actions.ProjectPropertyDialogAction.run(ProjectPropertyDialogAction.java:79)
    at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
    at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
    at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
    at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
    at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5348)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1348)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4602)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4183)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
    at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
    at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:498)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
    at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
I found a similar error in eclipse forums but couldn't make any of the proposed solutions work. Could anyone give a clue of what is going on?
Thanks in advance!
V
