LPC845-BRK: Error JP1/JP2 in doc
1234567890
Manual and schematic mixed up function of JP1 and JP2.
BlackNight
Yes, the JP1 and JP2 were indeed mixed up in the board document, I had found this while writing up Tutorial: Transforming the NXP LPC845-BRK into a CMSIS-DAP Debug Probe | MCU on Eclipse. I had reported the problem and received an updated document (attached) which should be on the web soon.
I hope this helps,
Erich
ZhangJennie
In order to check this problem efficiently, can you please specify
1. what's the concrete problem you have?
2. what's the expecting result?
Jun Zhang
