Hi, I am developing a driver module on LS1046A processor (and Linux OS) and want to use fsl-qdma driver for dma data transfer from memory to memory. I am looking for some reference/documentation on how to use the fsl-qdma driver for this purpose. Looking at the fsl-qdma source code, I see that the current memcpy call only supports one source buffer and one destination buffer. No scatter/gather list support. I want to transfer from a list of buffers to a memory destination. How shall I use source scatter/gather list with this fsl-qdma driver ? I dont see DMA_SG option also when requesting a channel. Any pointer or advice will be very much appreciated.
The SG mode has been removed from kernel dma engine driver.
If you want to use SG mode please use the LSDK branch linux-4.9.
Pavel Chubakov
