I am using the MK22FN512xxx12 (LQFP100) processor connected to an Intel 8080 type LCD interface.
16 bit Data FBD[15..0]
1 bit GPIO for Register / LCD Data control
Rd, Wr, CS,CLK
I am using the Flexbus setup at 16 bit mode and the configurator tool is giving me warnings about the higher Flexbus pins 16,17,18,19,20,25,26,27,28,29,30,31 which I am not needing.
Is this normal?
Solved! Go to Solution.
Hi Gary,
MCUXpresso Config Tools is expecting you to configure address bits in FB_AD but in your case using an LCD you don't need them.
Your program should work fine despite the warnings about those pins.
Felipe
Hi Gary,
Felipe
