It depends on how you have setup your bootloader and application.
If your bootloader does not alter the application in any way (e.g., relocation of vectors, decryption, etc.), it's straight-forward.
Simply concatenate the two S19 files into one. You may have to remove duplicate S9 records, if your tool complains.If your bootloader relocates vectors, you'll have to add a conditional to prepare the app with vectors in their final position, so they don't overwrite the bootloader's ones.
If you use encryption, you'll have to add a conditional to prepare the app unencrypted.
Message Edited by tonyp on
2009-01-12 02:17 PM
