Hi Katback,
KATBACK wrote:
Does the ADC convert negative voltage?
Answer: No!
KATBACK wrote:
If so, where is the negative bit stored?
Answer: Not Applicable!
If you have a signal that goes positive and negative you usually use an op-amp to "level shift" it up so that the entire range of the signal now falls between 0v and Vcc
