S32DS How to install the old version SDK(2.9.0)
liuruowen
How to install the old version SDK(2.9.0) when the S32DS is installed the new version(2.9.2)?
Tags (3)
stanish
The older version of SDK should be available in your current S32DS layout if you have the latest patch installed.
Anyway, SDK v2.9.0 was released in update 7: https://community.nxp.com/docs/DOC-341408
If you create a new project you can choose from different version of SDKs:
or create a new project form Example for specific SDK version:
Hope it helps.
Stan
