Security Boot LPC1830
Question asked by Ken Su on Jan 27, 2019
Latest reply on Jan 29, 2019 by Ken Su
Dears,
I have a question about LPC1830 security boot,
After reading the LPC1830 user manual and lpcscript user guide, the security boot will be:
Encrypt :
      Call Image Manager to encrypt the binary image with the 128-bit key and add the required
header on PC side.
Program the AES 128-bit key:
      Call LPCScrypt and pass a single command to program the AES 128-bit key into OTP
memory on the MCU.
After power reset, the boot code will decrypt the boot image by AES key and header,
Question1: Can I do this in my application code?
Because I will have two image, image 1 boot without security encrypt, image2 will encrypt by lpcscript tool , and the image1 will decrypt image2 to another ram(ex: SDRAM). In other words, my image1 do the job same as the ROM boot code. Is it possible? I think one of the problem is I don't know the header information added by lpcscript tool.
Or I don't need know the header information because AES engine will do this job, --> I can do the same as job as ROM boot code.
Question2:
If my idea is not work, from user manual, the AES engine can use "key2" to decrypt data, the problem will be "how can I encrypt the image with lpcscript tool" and then decrypt this image by key2?
Ken
