I am trying to implement a simple project where I send a message from node 1 to node 2 using CAN. Both the nodes are lpc1769 boards. I suppose there are some issues with the code. As I am a beginner, I request you to provide any reference codes I can look into(polling implementation will be more helpful).
Thanking you in advance.
Hello Aniket Gajare,
I recommend you refer to the "periph_can" demo under LPCOpen, there is a readme.txt ,
introduce how to use and config board in detail, please download it at :
LPCOpen Software for LPC17XX|NXP
If have any question when using , please contact us without any hesitate.
Hope it helps,
TIC
