DALI master example with a microcontroller which contains at least 2 UARTS
pascalcarreweyn
I would like to create a dali master.  I need at least 2 UARTS (1 for the dali and one other port for serial communication).
Which microcontroller would be adviced ?  I'm searching for a microcontroller where the DALI master software is supported in the nxp examples.  The microcontroller examples i found only have one UART.  I tryed to make a new project with an  LPC1124 but there i got stuck on some compiling problems which i don't understand.  I'm not experienced with the MCUXpresso, so this makes it a bit hard to do for me.
So to be very clear : i need an LPC microcontroller where there is an example of the DALI software AND which has at least TWO UARS.
Please advice.
Tags (2)
Hello pascal carreweyn ,
- About the development DALI ,  I recommend you first have a look at "DALI getting started guide"
Scalable Entry Level 32-bit Microcontroller (MCU) based on Arm Cortex-M0 Cores|NXP
-  " I tryed to make a new project with an  LPC1124 but there i got stuck on some compiling problems which i don't understand.  I'm not experienced with the MCUXpresso, so this makes it a bit hard to do for me."
About compiling error, you can share your project, then I can help you check it .
Hope it helps,
TIC
